pdlcstll
Posted: Tue May 15, 2007 10:47 pm Post subject: JVC AV-56WP74 projection HDTV |
| Can anyone help me with a convergence problem. I can adjust my red horizonatal convergence but the vertical will not. Has any one experianced this same or simular issue with the JVC AV-56WP74 Projection HDTV? |
Posted: Tue May 15, 2007 11:34 pm Post subject: |
| Replace convergence IC's, STK392-110's, check all resistors around them. |
snowking_141
Posted: Tue May 15, 2007 11:51 pm Post subject: |
Let me know how it works for you.
I replaced my IC's because the red horizontal was all wavy. It fixed that but I had already mess with to much that I shouldn't have and when I tried fixing that I heard a pop and lost control of the vertical on the red I did find a bad resistor so I changed them all. I still can't adjust the vertical. So I guess if the IC's work for you I will buy more. |
Posted: Wed May 16, 2007 11:29 pm Post subject: |
| snowking_141 wrote: |
PM me. Here's what I PM'd him:
"IC 804 & 805. Check R842 2.2 ohm 1 watt, and R846 1.5 ohm 1 watt. R842 is for the red horizontal adjust and R846 is for red vertical adjustment. STK392-110's come in it I put in STK392-180's, 11 watt vs 18 watts. These seem to puke after about 2 1/2 years. The board should be mounted behind the speaker grill and cover. Let me know."
I have never had a JVC kick my arse. I'll repost convergence IC guides again. |
Philips TPM2.1E LA.part15 Philips • TJ [radial thru-hole] GF Series TJ [Tong • tv plasma pdp 433pe pu Pioneer • ICON V01N01 Oct83 apple • 28WZ610S Thomson • Apple Powerbook G4 A1139 MLB PB17 051-68 • DOS 27 Release Memo May72 IBM • SLV-D350P 550P Sony • 19771123 Pointers xerox • FC8402 Philips •
