Toshiba convergence 42H81
Goto page Previous  1, 2, 3  Next
PostPosted: Wed Jul 11, 2007 12:02 am    Post subject: Reply with quote
R7731/7736/7725/7716/7721/7711 1.8 ohm 1 watt.
Phils
PostPosted: Mon Jul 16, 2007 4:23 pm    Post subject: Reply with quote
Wow... it's sure nice to have HD instead of Blur-vision again!!
The blue convergence is controlled by Q752, which is the one towards the front.
I know this because I carefully studied the schematics and the board traces, both in the manual and on the board. I then replaced Q751 and R7716. Put the set back together. NO CHANGE.
So I replaced Q752 and R7731. I noticed the tell-tale blister on the resistor (but it was impossible to see before it was pulled out).
Problem solved!
Thanks for your help!
Phil
Richey
PostPosted: Wed Jul 18, 2007 11:44 pm    Post subject: Reply with quote
Hey minnie, thanks for pointing me to this thread. I too found the bad resistor and just finished soldering a new one in place and the TV is back to normal again! Yay! I had to go into the 56 pt convergence, but that was a breeze comparatively! Thanks again to all!
Richey
PostPosted: Wed Jul 18, 2007 11:49 pm    Post subject: Reply with quote
For others out there, here's what you may be looking for:
This was directly under the heat sink that the STKs are attached to.
The light blue one at the back was replaced last year while the TV was still under extended warranty and had the same problem.
Phils
PostPosted: Thu Jul 19, 2007 8:18 pm    Post subject: Reply with quote
Good job Richey!!
You didn't need to replace the SDK amp just the resistor?
Phil
guestabc
PostPosted: Fri Jul 27, 2007 4:07 am    Post subject: HDX82 problem...Please help... Reply with quote
Hello All,
I replaced the STK-392 110 IC's for the dreaded convergence problem. I forgot to correctly document the connectors and I an stuck with a wires with a connector that is not going anywhere (Blue and white - 9 pins) and a rear connector on the vertical metal box (8 pins I think) . I would appreciate it if someone can help me out.
Thanks
Phils
PostPosted: Fri Jul 27, 2007 5:52 pm    Post subject: Reply with quote
guestabc,
I was able to pull the entire "mother board" out and make my repairs without disconnecting even one cable.
BUT I thought I'd be disconnecting them all so I took a whole bunch of digital photos from many angles. If your model is the same or similar I can email the photos to you. Actually, I suppose I could put them into an album at Webshots and give you the link too.
Phil
Richey
PostPosted: Sat Aug 04, 2007 9:56 pm    Post subject: Reply with quote
Unfortunately we had replaced the two STKs first and the TV was still doing the same thing. Then after closer inspection I found the bad resistor. The STKs may have been ok... ? Ah well, I kept them.
PostPosted: Sun Aug 05, 2007 5:35 pm    Post subject: Reply with quote
The STK's blow the resistors when there bad. So there junk.
Litherish
PostPosted: Thu Nov 29, 2007 5:31 am    Post subject: Reply with quote
I've got the same problem, this thread has shown me what I need to do. My only question is if it would be to my advantage to replace the STK392-110's with STK392-150's?
Page 2 of 3
