trouble with kv34hs510 not turning on
badshrimp
PostPosted: Sun Aug 19, 2007 1:22 am    Post subject: trouble with kv34hs510 not turning on Reply with quote
i have a 34 inch kv34hs510 that has worked fine until today. We turned it off and walked out the door and i can't get it to turn on. unplugged from surge protection and cable box and there has been no storms in the area to speak of....i can hear it attempting to turn on then it seems to shut off....help.....
PostPosted: Sun Aug 19, 2007 6:33 pm    Post subject: Reply with quote
How many times does the red light blink?
badshrimp
PostPosted: Fri Aug 24, 2007 8:51 pm    Post subject: Reply with quote
it blinks 6 times. it came on once and one of the kids must have pushed the on off button instead of using remote....
PostPosted: Fri Aug 24, 2007 10:19 pm    Post subject: Reply with quote
The regulated 5V line is monitored using Q2314 and Zener diode D2310 (3.6V) on the M-board. The output of
the 5V regulator IC504 is applied to the emitter of Q2314. In normal operation, Q2314 is turned ON and D2310
is conducting holding the base at 3.6V. Approximately 2.8V is applied to System Control IC2300/pin 43 indicating
proper level of the regulated 5V line.
If the 5V line falls below approximately 4.5V at the emitter of Q2314, D2310 will stop conducting, Q2314 will turn
OFF and a Low will be applied to IC2300/pin 43. IC2300/pin 69 will then turn OFF the AC relay.
The AC relay shuts down and the Stand by/Timer LED flashes a 6X sequence.
IC504 #6-700-898-01
cory
PostPosted: Sat Aug 25, 2007 9:11 pm    Post subject: Reply with quote
minnie dosent this set have that 18 pin ic for high voltage startup and regulation.3001? on top of ic.ive seen this ic give false reading of error code for low 5 volts.also same ic in power supply.one usually goes bad.ive found as long as 135 volts from power supply is there it is the high voltage ic.near flyback.
badshrimp
PostPosted: Sun Aug 26, 2007 9:31 pm    Post subject: not as savvy of tech fix Reply with quote
Minnie/Cory the TV is coning on occasionaly and working fine with tutning off with remote and then it stays off for a while. based on your description is this something a novice like myself can do or do i need someone with your skills? If so what will this set me back roughly...thanks.
PostPosted: Sun Aug 26, 2007 11:02 pm    Post subject: Reply with quote
The real fix is, seeing as the D board is no longer available, Sony calls it a phase 3 repair. You send the D board in, they jig it, fix it, and send it back. Only thing is A1300319A subs to RRA1300319A.
http://www.tritronicsinc.com/
The cheapest way to do it right. Just be aware there's a $100 core. You get that back when they get your board back.
badshrimp
PostPosted: Wed Aug 29, 2007 10:50 am    Post subject: Reply with quote
Minnie does it make sense to have a tech come out? like i say i am a novice and figure i will do more damage trying to get to the board....if so can anyone give me some near 21054 zip code that they would recommend?
thanks for all the help and advice.
