Granito Guest
Posted: Fri Sep 07, 2007 6:19 pm Post subject: Identify component |
What is this?
Looks like a common transistor TO-92 and has the following printed on it.
RTAD-BAPOD. Definetely not a transistor. |
Posted: Fri Sep 07, 2007 11:52 pm Post subject: |
...May still be a transistor ? --may simply be a "house number"
What is it out of? How/if does it measure? any reference on the board? pictures? |
Posted: Sat Sep 08, 2007 5:13 pm Post subject: |
| Una forma Ingeniosa de Reparar los reguladores STR 10006 y similares / procedimiento aportado por Gustavo A |
Posted: Mon Sep 10, 2007 5:28 pm Post subject: |
| vtech wrote: |
It acts like a voltage regulator. 12V in and 2.2v out. The centre lead is pegged to ground through a diode. It is U1 on the board but they use IC9 for another voltage regulator. The 2.2V is supposed to be Vcc for a display. This is a CD player/radio etc. Audiologic.
I don't have any diagrams or anything. The 2.2V doesn't seem like a Vcc voltage. Maybe I am wrong. |
Granito Guest
Posted: Mon Sep 10, 2007 5:34 pm Post subject: |
Sorry, this was my reply
| vtech wrote: |
Granito Guest
Posted: Mon Sep 10, 2007 5:38 pm Post subject: |
Sorry amigo, can't reply in spanish. That's a 5 terminal device, mine is 3 terminal. Not sure what you are suggesting. |
Posted: Mon Sep 10, 2007 6:46 pm Post subject: |
| Granito wrote: |
| vtech wrote: |
No doubt it is some kind of a reference regulator & yes the 2.2 V does sound low (the diode on the ground leg actually adds about .6 V to the output)----- but it may still be ok depending on the display ckt . ---some things to check (w/out a print)
1) Are there any electrolytics on that 2.2 volt line? (V Ratings could give an indication)
2) What type of display is the 2.2V feeding? Are there any numbers on the display itself? or does it use a display driver? |
Granito Guest
Posted: Mon Sep 10, 2007 7:36 pm Post subject: |
| vtech wrote: |
| Granito wrote: |
| vtech wrote: |
Granito Guest
Posted: Mon Sep 10, 2007 7:46 pm Post subject: |
Screwed up previous post
Electrolytics are 16V
The display is
Arlight R&D Ltd.
NXT-402 Display board
20-T4025-02
I can't find anything on it.
No separate display driver.
Problem is all control lines go into the display and out of it. Including Power on/off.
It doesn't power up the display so nothing works.
Some processing takes place in the display |
Posted: Tue Sep 11, 2007 1:53 am Post subject: |
Not sure if you undrestood about the capacitors; 16volt electolytics on the output line which reads 2.2v?---Ok, that is more than obvious that either it is being pulled down or the regulator is bad.
Again, IF infact there are 16v electrolytics on THAT line, you could safely substitue an external DC supply (~5-9 V) as a test measure. Otherwise, try finding a print which may be a lost cause in itself. |
