a.fisher1 Guest
Posted: Fri May 06, 2005 10:09 pm Post subject: Static Click Noise- Toshiba 51" HD |
| I have a Toshiba 51" HD TV Hooked up to Digital Cable. If the TV has been on for a while the speakers start to click, almost sounds like a static electricity sound. I tried spraying static guard around the TV and around the speakers to no avail. Can anone out there help me? |
walter58
Joined: 11 Apr 2005 Posts: 20 Location: Antwerp,Belgium
Posted: Sun May 08, 2005 10:41 am Post subject: speakers high definition tv start to click |
Hello,
It could very well be that the clicking comes from spikes which appear on your mains supply !!!
I had the same problem, when certain devices on the same mains circuit switch on and off (f.e a refrigerator), disturbing spikes are modulated on the net,causing speakers to crack, you should see also a sign of that in your video(no must but it could be).
So what you might have to do is to put a netfilter or mainsfilter between the powerpoint and your tv, and it might cure your problem...
this filter only works when it is earthed, so you need a mains socket with an earth connection !
It has to be a real filter, not a protection device, which are currently sold!
You can find such a filter in an electronic shop or at your TV dealer.
But first be sure that what I say is the real problem.
Succes !!
Walter  _________________ never give up when you are looking for something,unless you're forced to ! |
