Rob Gel Coat Guest
Posted: Mon Nov 12, 2007 1:06 am Post subject: Mitsubishi VS50707 TV needs to WARM UP for 15/20 mins. |
Mitsubishi VS50707 TV needs to WARM UP for 15/20 mins. before I can view an unscrambled/wavy picture. |
Posted: Mon Nov 12, 2007 1:04 pm Post subject: |
Most likely, a bad electrolytic capacitor somewhere. When those parts are near failing, they work somewhat better when they are hot.
Look for capacitors that are apparently bad (leaking, swollen top, the shrink tubing around them damaged by heat from the capacitor etc).
Try troubleshooting by heating/cooling (hair dryer / cooling spray) of suspect capacitors. |
Posted: Mon Nov 12, 2007 3:59 pm Post subject: |
Also well-known for possible CRT coolant leakage which can cause variety of problems. check for "greenish" corrosion on main PCB under each CRT. |
Posted: Mon Nov 12, 2007 9:29 pm Post subject: |
Naw, on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also. Change those 2 if that doesn't do it I'll pull the print. |
thf-13p NOKIA • panasonic+SA-HT70 panasonic • 81470A(DAS1200) Keithley • hfe dynaco pas-3 series ii schematic DYN • hfe scott 420a schematic HH SCOTT • Prology CMD-100R Prolodgy • compaq armadastation, ministation e, min • euro4 panasonic • RXD-V525 & V626 & V727 Kenwood • 01inst NOKIA •
