Frank Guest
Posted: Tue Nov 13, 2007 11:25 pm Post subject: 12vDC Fan to cool the power supply? |
| Hi guys i also have a KV36HS500 and i have no fault yet,cross your fingers; since many of you guys that are having faults in the power supply with the MZ3001 IC's, i've read in a forum that i can't post there,so i can't ask questions,it's about installing a small computer fan 12vDC over the D board so it can cool it, so it will last longer without a fault due to over heating of the ic's and power supply.i have here a 12v o.25A fan, is there a 12v connection in the D Board that where this fan can be connected to? or just have an outside small transformer with a switch that manual can be turned on just my thought, would this be a good practise that will benefit the the cooling power supply and on the long run the TV? any technical suggestions? Thanks in advance. |
Posted: Tue Nov 13, 2007 11:44 pm Post subject: |
| CN9100 pin 1 +12vdc. |
Frank Guest
Posted: Wed Nov 14, 2007 1:27 am Post subject: |
| Thanks Minnie, this fan that i found is a brushless DC 12V =0.25A it has a small circuit with 4 diodes rectifier and a 2200uf 25V filter cap,this fan was used in a small psychedelic light system it had 2 small red lights,and hed this fan underneath it, should i take the litle rectifier circuit bord out and use only the Fan itself? |
Posted: Wed Nov 14, 2007 9:16 pm Post subject: |
| Pull it out and use a 9vdc battery to make sure it works. |
Frank Guest
Posted: Wed Nov 14, 2007 11:58 pm Post subject: |
| minnie wrote: |
Thanks Minnie, i already took out the small board and connected a 12vDC small power supply and it works fine as well.Minnie i was thinking of opening a hole on the back cover just behind the flyback and just put it there pumping cool air inside just like a computer power supply,i'm also thinking instead of opening the back to connect to pin1 of CN9100 for the 12vdc suplly which one don't know if that will over load the output of CN9001,so i'm thinking of using an external 12v 250milliamps power supply with a manual switch.i don't fill like opening the set without any fault just to do the experiment.because the set is running fine now and has been for the last 5 years. Minnie What you think of this idea? Thanks in advance. |
aspire 5600, travelmate 2480, 4220 servi • 30090-90002 S44-48ins Dec83 HP • SternRadioSonneberg Meiningen6106 sch RF • 2sc5012 2sc5007 2sc4227 2sc3583 2sc3604 • hfe philips az1009 1010 service en Phili • hfe dv-50a 563a-s service rrv2740 en P • 2116B PressRelease Aug68 HP • Panel CMO N141C3-L07 4 [DS] . Various • 07 Exploded View & Part List Samsung • B51-7967-00-SD Kenwood •
