Frank Guest
Posted: Mon Jul 16, 2007 7:16 pm Post subject: Toshiva36A50 |
I have this Toshiva chassis TAC0010 ,with white line in the midle with 6 inch field colapse with sound ,i suspect TA8427K,any tips or pins out volts on this vert IC, Thanks in advance. |
Posted: Mon Jul 16, 2007 10:38 pm Post subject: |
Vertical IC failing is common on this set. |
Frank Guest
Posted: Mon Jul 16, 2007 10:44 pm Post subject: |
Thanks Minnie, |
Frank Guest
Posted: Wed Jul 18, 2007 1:10 am Post subject: fied toshiva 36A50 |
Fixed set by resodering Diode Between pin 6 and 7.on the vert. |
Posted: Wed Jul 18, 2007 4:05 am Post subject: |
Bad solder connections? |
Posted: Fri Dec 14, 2007 12:00 am Post subject: |
I'm having the same problem with my toshiba 36a50. Can anyone tell me where the vertical IC is so I can try to resolder anything suspicous? |
Posted: Fri Dec 14, 2007 11:17 pm Post subject: |
IC301 TA8427K. |
CDC-X527M AIWA • BX376A Philips • 075103800web Tektronix • 2sa1418 Sanyo • PHILIPS - D6920 Philips • 5990-6050EN M9392A PXI Vector Signal Ana • hfe cd880 service nl Philips • a-200 HP • JVC TM-H1900G ch.S1 sc.d panasonic • MDL [non-polar radial-axial] B04 Series •
