Posted: Fri Dec 28, 2007 12:18 pm Post subject: |
i think its the processor that has the prblem with my L32, the remote pin does not goes high when i press the power switch, but the 5volt is present and the orange led lights on. Any help from you will be much appreciated. Tnx. |
ARC9888 Guest
Posted: Mon Jan 28, 2008 9:44 pm Post subject: power board fuse |
Does anyone know where I can buy the fuse for the power board of Vizio L32 LCD tv? |
Posted: Tue Jan 29, 2008 12:10 am Post subject: |
Do you think it just may help if you posted exactly what kind of fuse it is? |
Posted: Tue Jan 29, 2008 12:27 am Post subject: Re: power board fuse |
ARC9888 wrote: | Does anyone know where I can buy the fuse for the power board of Vizio L32 LCD tv? |
Value should be list right by it. |
arc9888 Guest
Posted: Wed Jan 30, 2008 3:56 am Post subject: fuse same as yeomp's |
yeomp said:
I just opened up a Vizio L32 LCD tv to fix the power supply. The fuse was blown and so I replaced it. Now, I get a 5.1v output of v1 but v2 and v3 are both dead. Also it looks like the heat-sink is hot, it is reading the same 5.1 volts from output ground.
I have the same issue that the fuse of Vizio L32 power supply board was blown. I would like to ask "yeomp" or anyone who know where to get this fuse. Since "yeomp" just replace it by himself, he should know where to. The fuse was like a small short cylinder with two leads and marked with T4.0A 250V.
Best wishes |
cwoods98 Guest
Posted: Fri Feb 29, 2008 4:39 pm Post subject: Vizio Parts |
Vance Baldwin Electronics is the distributor for Vizio TV parts |
jophisd Guest
Posted: Mon May 19, 2008 3:58 am Post subject: Vizio L32 |
I just got a Vizio L32. It is in good condition, but wont turn on. When I plug it in there is nothing that happens. No lights. Nothing when I press the power button. Do I need to replace the power supply board? If so could you give me a link of where to buy it?
Thanks,
Joe |
Don G. Guest
Posted: Fri Jul 04, 2008 5:14 am Post subject: L32HDTV10A |
I have a Vizio L32HDYV10A with a bad power board. Does anyone know what IC901 is? Mine is burnt so much I cannot read the chip to find a replacement. |
Don G. Guest
Posted: Fri Jul 04, 2008 5:18 am Post subject: L32HDTV10A |
Does anyone have a schematic of the power board for a Vizio L32HDTV10A? |
Panel CHIMEI INNOLUX M270H5-LA2 2 [DS] . • ixbk75n170 ixbx75n170 Ixys • Yamaha • PCG-GR150 (K), PCG-GR170 (K) Sony • LCT-2662 Akai • English 2014-03-16 PDF 2.21 MB 5991- • KRC-2902 Kenwood • trouble EP2050 116 Minolta • block panasonic • hgtg20n60b3d Fairchild Semiconductor •
