Nibbos
Posted: Fri Oct 26, 2007 10:53 am Post subject: |
many thanks
Nibbos |
angeloformica Guest
Posted: Sat Nov 24, 2007 12:37 pm Post subject: messagio |
[quote="Anonymous"]Hi all,
I want say you TANKS, because I fix the same problem that you had
just following your suggestions.
Angelo Formica, from palermo italy
[email protected] |
Posted: Mon Feb 11, 2008 11:45 pm Post subject: |
| Same problem Low Volume on CMT-CP101. Read one of the solutions and thought that is stupid cannot possible work BUT it HAS. Worth a try as is a NO COST solution. Put player into CD mode and then press PAUSE button and leave for a couple of hours. Why it works I have no idea but it has. Hope you get the same success. Peter. |
dark_rain Guest
Posted: Sat Apr 05, 2008 11:15 am Post subject: Re: MD inputs |
| For all those interested MD input is controlled by q310, which is a krc103. |
Dann-o Guest
Posted: Mon Aug 25, 2008 9:38 am Post subject: Fixed Stereo |
Just want to thank bluerobboman for his advice.
Had the same problem with my CMT-CP101. Ordered the KRC103S from visionaid, swapped it out with Q330 and am now catching up with favourite tunes after a prolonged separation!
It was an easy job and for only 8 quid I'd recommend anyone with the same problem to give it a go. |
yo3hjv Guest
Posted: Sun Sep 07, 2008 12:43 pm Post subject: No audio |
| I just changed the jumper and all is fine now!!! No need to change the Q330. |
qwx Guest
Posted: Sun Dec 21, 2008 11:40 am Post subject: thank you |
| Hi all, thx very much. I rang up the local Sony part supplier and bought KRC103S (costing less than AUD 5). Also got 470Ohm resistor from an electrical shop. Got them changed, and worked perfect! |
Posted: Sun May 30, 2010 7:38 pm Post subject: Who needs mute? Remove and Short-Circuit Q330! |
I do not need mute. And I do not have a replacement for Q330. So I short-circuited pin 1 and 2. It works!
Pin 2 is that one, which shows up, pin 1 is the right one of the two who show down.
Regards
P |
stefe
Posted: Wed Nov 03, 2010 12:49 pm Post subject: KRC103s |
Sid, Im under the impression that "the toon" means Newcastle upon tyne, UK, and if it does, do you have any more KRC103s' or the DTC124EK's?
Im happy to collect, Thanks Stefe,
Also, failing that, can the French guy, post a pic, and which les of the transistor to soldier? Thanks |
pasty lover Guest
Posted: Sun Dec 19, 2010 8:32 pm Post subject: |
First off thanks eveyrone great advice, I've somehow managed to short circuit this transistor and now the system will not power anything other than the display, the cd will not spin up the LED's will not light up etc any idea anyone if there s a fuse I've blown
Regards
Jason |
