james10s
Posted: Sun Mar 09, 2008 5:32 pm Post subject: Denon UD-M3 playback problem |
| Anyone help. My Denon UD-M3 is not able to play commercial music CDs. It skips, repeats a section continuously, freezes, etc. In desperation, I've tried a high-quality cleaner to no avail. Anyone with instructions/suggestions on how to replace/repair the CD drive? Thanks. |
confudler Guest
Posted: Tue Mar 11, 2008 1:53 pm Post subject: Another satisfied repairer (almost) |
Don't know what inspired me to find a fix today but this one was easily found and worked.
I first tried to leave the fuse on top of the pcb (wrapped in insulating tape natch) but this interferes with the mechanism (the upper pcb drops down on it when the drawer opens) so I put it at the side.
I do now have the same problem as an earlier user - the cd skips unless the player is propped up on one side. I think its the cables to my fuse causing the cd mechanism to be not horizontal (the cd makes noises as if it is rotating wonkily). Will open up the box again and if necessary, make a notch for the cables. |
JonB Guest
Posted: Mon Mar 17, 2008 7:53 pm Post subject: Another ud-m3 fixed |
| O the satisfaction! Now hypnotised by the CD drawer going in and out and sound out of the speakers was a bonus. Only 2 screws left after re assembly, which for me is a result! Proof that anyone can do this fix. Thank you. |
GPC
Posted: Thu Apr 17, 2008 11:57 pm Post subject: Denon UD M3 |
Thanks for posting, I fixed my bothers unit no problem. Then I decided to buy myself one off ebay with the same fault........not so great ! Fitted fuse / fuse holder, and the tray is now powered up.
But.... the tray opens as it should, press close and it closes, the carriage moves up then moves down and tray opens by itself.
The cd drive motor is not turning and the tray needs a little push to close the last few m/m.
Any ideas gratefully considered.
Cheers everybody. |
Stu Guest
Posted: Fri Apr 25, 2008 12:15 pm Post subject: Re: UDM3 FIXED!!!! Located PR003 and replaced |
Hi
I cant access the links to the pictures. Could someone re-post images please?
Cheers |
GPC
Posted: Fri Apr 25, 2008 7:45 pm Post subject: PR003 Location |
I couldn't open the pics either, but from memory,
1. Remove the cover.
2. With the control panel facing you reove hte 4 screws holding the cd mechanism in place, although the wires are still attached this can then be moved will the right.
3. PR003 is in the bottom L/H corner nearest to you (just visible were you have removed the cd mechanism).
4. I put my fuse holder on the L/H side in the space by the outer cover.
Also as I found, if you have removed the cd tray from its mechanim the open/close gearing mechanism must go back in the same mesh as it came out.
Hope this helps. |
thegasman
Posted: Sat Apr 26, 2008 3:32 pm Post subject: PR003 500ma |
Wow thanks for the info on this thread, I started this morning by typing the model no and fault into google three hours later its working. Cost was 50p for a fuse from a local tv repair guy, this cd player has been under the bed for 3 years.
Cheers me dears |
Lucy Newbie Guest
Posted: Sun May 11, 2008 8:22 pm Post subject: Denon UD-M3 CD problem |
Hi, I have the same model with the same problem... But I can't weld and have never taken anything apart I live in north London, any chance someone could help me?? |
biddy67
Posted: Sun Jul 06, 2008 1:34 am Post subject: |
Another successful repair here. I found a good place to mount the fuse. I had a 1-1/4" fuse holder already, got a 500mA fuse at Radio Shack and mounted it vertically to the back left hand corner near the transformer, where there is a notch in the black plastic part that holds the tray. I drilled a 1/4" diameter hole approximately .9" down from the top in the black plastic on the left side and secured it with a dab of "shoe goo" adhesive (this stuff is great, will glue to plastics) and a cable tie. It will end up being across the fuse, requiring it to be cut to replace the fuse, but that's life. You have to get the height right on the location of the cable tie or it will interfere with the cd tray placement. There are smaller fuse holders available that would fit better, but the 1-1/4" will work. I've tried to attach a photo of what I did.
Anyway, thanks again. Got this unit "broken" for $15 and now works perfect.
[/img] |
Posted: Sun Jul 06, 2008 5:01 am Post subject: |
| biddy67 wrote: |
[/img] |
Toshiba Satellite L450D (Compal LA-5831P • 2sd1292 Rohm • BEKO chassis K5 BEKO • 67194-WW-1 MAKITA • sti260n6f6 stp260n6f6 . Electronic Compo • CUC7350 Grundig • tip3055 tip2955 ON Semiconductor • V711UK Toshiba • PL92 ET-SB-EX-SI 1267527133 Philips • BX-1 Yamaha •
