RODALCO
Joined: 28 Oct 2006 Posts: 30 Location: Auckland - New Zealand
Posted: Sat Apr 26, 2008 11:52 pm Post subject: Sony TC-730 Reel to reel tape recorder |
Hello forum members.
I have a problem with my Sony TC-730 Reel to reel tapercorder - amplifier machine.
It suddenly stopped while playing music, a small puff of smoke came out of the vents and that was it.
Today I tackled the machine and decided to have a look at it (about 3 months later).
Luckily I have a second Sony TC-730 which works fine.
I checked the mains fuse which was ok.
Had a look by taking the chassis out of the wooden casing and looked for the obvious. Nothing as such looks burned out or has a suspect smell.
No bulged capacitors.
The capstan motor works in both directions but no response from the reel motors or the solenoids.
The amplifier section works fine.
Unfortunately I can't find my manual which has an electrical schema in it.
Has anyone worked on one of these machines and knows the symptom ?
Many thanks for your reply.
Regards, Raymond |
Posted: Sun Apr 27, 2008 2:51 am Post subject: |
Having another working unit can help out better than a schematic.
Sounds like something gave up the ghost in the power supply or drive section such as a regulator/transistor/etc ..look closer around the power supply or follow back from capstan.
You can always set up the working unit as a reference unit on the side to do an A-B spot-check voltage test. |
RODALCO
Posted: Sun Apr 27, 2008 4:39 am Post subject: |
Thanks vtech for your reply,
it did cross my mind but at this stage I am not too keen to take the other unit apart.
Access to some parts is quite hard, even to do measurements on certain circuit boards.
I might end up with two broken units.
I'm hoping that someone with Sony experience has done repairs on these units or know about particular weak points.
I have heard that these are complex machines to work on.
Thanks, Raymond |
Posted: Mon Apr 28, 2008 5:58 am Post subject: |
| Try paul stennings vintage tv and radio forum a lot of reel to reel people there |
RODALCO
Posted: Thu May 01, 2008 9:56 am Post subject: |
Thanks guest,
I did posted my question there too.
I'm checking the relays when time allowes as was suggested by one of the members. |
