KYRLAG Guest
Posted: Wed Jan 25, 2006 11:45 pm Post subject: TV SONY KV25FX30 PROBLEM |
MY PROBLEM WAS THE STK2515 TRANZISTOR FOR HORIZONTAL WAS BURND AND ALSO THE HORIZONTAL TRASFORMER. I CHANGE BOTH THE TV START WORK. THE HIGH VOLTAGE IS OK BUT THERE IS NO ADJST AT BRIGHTNES IF YOU LOOK CAREFULY YOU WILL SEE THE PICTURE IN THE DARK SCREEN. THE SOUND IS OK. |
hmasri69 Guest
Posted: Thu Jan 26, 2006 9:53 pm Post subject: i solved for y |
i was have the same problem
there is 2diod & resistanc all(smd)burnd near the control ic
i dont have the no now............ |
Joentje
Posted: Thu Feb 02, 2006 7:23 am Post subject: |
Check/replace these components in the ABL-line, 2x SMD-zenerdiodes 6,8V, 1x SMD-diode 1N4148 and 1x SMD-resistor 220 OHM.
If the problem isn't solved, replace the processor (SMD).
In 99% of the cases after a defective LOT the processor is also defective. |
Joentje
Posted: Thu Feb 02, 2006 7:25 am Post subject: |
I guess your TXT and OSD are OK. |
Baeteman Guest
Posted: Mon Feb 06, 2006 5:13 am Post subject: |
Hi there,
Have you adjusted the Vg2 pot on the new flyback trafo ?
They are always deliverd with this one fully CCW.
Kind regards. |
fdms8670s Fairchild Semiconductor • s a 18 panasonic • 15mm itautec • 04-TI-005 panasonic • KSC [radial non-polar] NM Series KSC [Ki • CTM511 teac • [radial thru-hole] KLH Series Koshin • 2sd1716 Inchange Semiconductor • ixta2n100 ixtp2n100 Ixys • pm3244 mods Philips •
