JordanV26 Guest
Posted: Tue Sep 03, 2013 2:37 pm Post subject: kenwood car radio |
Hi I have a kenwood car radio that every time I try turning it on the protect light turns on and the radio wont work. What are some things that could be causing it to do this? |
kenray Guest
Posted: Tue Sep 03, 2013 4:04 pm Post subject: kenwood radio |
First, you should check all of your speakers and speaker wires for shorts and grounds. If they check out all right, press the reset switch which should be on the subpanel behind the face. There will be a small hole about the size of a pencil tip. If there is no reset switch, disconnect the battery for a few seconds. If it still stays in protect, you may have a bad output IC. |
JordanV26 Guest
Posted: Fri Sep 13, 2013 5:45 pm Post subject: thanks |
Thank you for your reply im switching out the output IC. that's what I found to be wrong with it. Thanks again |
DMM7510 Firmware v1.1.0f Keithley • phb9nq20t phd9nq20t php9nq20t 2 Philips • ss8550 Secos • MaxLine ІІ 250 GB maxtor • tip3055 Bourns • PT-LB10NTU ALL SVC panasonic • 04-lubrication system Honda • Adj Di181 020 Minolta • QS-6 Alesis • stv355 CHOV •
