leo Guest
Posted: Tue Sep 28, 2004 12:31 am Post subject: 36' inch hitachi modl #36cx39b has 1 horizontal line |
MY 36' inch hitachi model #36cx39b has 1 horizontal line across the middle of the screen ..... HELP .. the TV is about 3 1/2 years old .... I can hear the channel but it looks like the whole picture is reduced to this 1 line in the middle
PLEASE RESPOND .. is it worth saving.. and what needs to be done
thank you
grazie |
voivoda
Posted: Tue Sep 28, 2004 11:48 am Post subject: fly |
check first flybeck transformer...if you dont now how ...don't try ...there is dangerous high voltage |
Posted: Fri Oct 08, 2004 4:24 pm Post subject: Re: 36' inch hitachi modl #36cx39b has 1 horizontal line |
leo wrote: | MY 36' inch hitachi model #36cx39b has 1 horizontal line across the middle of the screen ..... HELP .. the TV is about 3 1/2 years old .... I can hear the channel but it looks like the whole picture is reduced to this 1 line in the middle
thank you
grazie |
It has nothing to do with a Transformer.
Your Tv probably has a faulty Vertical Deflection Chip. I Don't know what type of ic is used but it can be a TDA 8350 or TDA 3654.
It is also possible that you have to resolder the contacts of the ic.
Succes!
Jeroen Hartman
Tv Engineer |
StarBaseONE2
Joined: 28 Oct 2004 Posts: 18 Location: North Alabama
Posted: Fri Oct 29, 2004 8:25 am Post subject: |
vERTICAL DEFLECTION CHIP IS MOST LIKELY THE CULPRIT HERE... CAREFUL ON RUNNING THE SET TOO MUCH BEFORE REPAIRS ARE MADE... IT WILL BURN A LINE WHERE YOUR SINGLE LINE IS NOW. tRY TRACING THE PICTURE TUBE YOLK'S 'v' WIRES BACK TO YOUR MAIN BOARD THIS WILL USAULLY PUT YOU WITH IN TWO SQUARE INCHES OF YOUR DEFECTIVE CHIP. iT USUALLY WILL AFIXED TO A HEAT-SINKING DEVICE AND HAS 10+ LEGS. GOOD LUCK! _________________ ...Somewhere on the fringes of the Cosmic Coast, and still only allowed a small bunk in the enlisted quarters!
StarBaseONE2 |
BEC Guest
Posted: Mon May 02, 2005 11:01 pm Post subject: Re: 36' inch hitachi modl #36cx39b has 1 horizontal line |
thank you
grazie |
I have exact tv with exact problem. Do you have an answer yet? |
Melw Guest
Posted: Wed May 04, 2005 3:21 pm Post subject: Hitachi |
It will probably be one of three things:
!. A bad solder joint on the vertical IC601
2. No 9 volt B+ to pin 1 or 25 volt B+ to pin 8 of the vertical IC
3. The vertical IC itself is bad
You might also want to check out www.FreeFlatScreens.com/?r=10948674 for an opportunity to earn a free replacement for this set with a little effort on your part. |
calamero Guest
Posted: Thu Aug 31, 2006 8:57 pm Post subject: THANKS!!!..Last post worked ..hitachi cpt 2198 |
Took my hitachi cpt 2198 tv apart because the bottom half of screen was beginning to vanish up towards top half of screen otherwise picture was ok ...i was told if i left it all id have left would be 1 single white line on the middle of the screen...i opened the back up AFTER DISCONNECTING FROM ELECTRICITY SUPPLY and noticed that the vertical ic chip IC601 (only verically standing chip i seen with a heatsink and close to where some wires connectec to actual tv tube)...seemed loose so ive resoldered the pins from bottom and everything seems fine and working...ive only just did it so if it goes bad again ill repost but for now complete SUCCESS!!!..thanks everyone:)
calamero |
timil_JD Guest
Posted: Sun Jan 14, 2007 8:03 pm Post subject: had the same problem |
Don't forget this model has like 30 protection thing in it don't do anything if you don't know them. Cauz you'll think that was the problem but it won't be. Mine toke over 3 month to get it fixed. |
