glyn27 Guest
Posted: Sat Feb 04, 2006 6:34 pm Post subject: kdc 3021 |
i have a kenwood kdc 3021 and the cd is stuck inside and the eject button doesnt work any suggestions thanks guys |
amz Guest
Posted: Fri May 26, 2006 2:55 am Post subject: Re: kdc 3021 |
glyn27 wrote: | i have a kenwood kdc 3021 and the cd is stuck inside and the eject button doesnt work any suggestions thanks guys | i have the same issue any help please would be greaty appreciated!!! [email protected] |
Nemmy Guest
Posted: Sat May 12, 2007 4:30 pm Post subject: Stuck CD in Kenwood |
I have a Kenwood KDC 9021, and get the same problem (I think). Happens when player loses power (battery removed for example). Player no longer thinks it has a CD in it, but won't allow the stuck one in it to eject, nor a (of course) a new one put in.
Solution: reset the unit (there is a recessed button on the faceplate for this). Downside is you need to re-enter all presets and setup as it's back to as it was out of the factory.
Potential solution: (sometime works) try to gently insert a fresh CD into the player, and you can sometime fool player into thinking the one in the unit is the one you've just put in. Then you should be OK.
Of course, hopefully after 12 month since you two posted I hope you've fixed it by now! However, someone else might benefit from this reply. |
elpenguino Guest
Posted: Wed Oct 09, 2013 9:41 am Post subject: Remove stuck CD |
These models with part numbers around xxx-x018, xx-x020 and so on suffer sometimes from slipping CD load/eject rollers. Basically have to dismantle to fix properly or try something like hotter/colder temperature.
You know this is problem if motors run when eject pressed, but mebbe results in E-04 or something.
Remove and dismantle for real repair. Can bodge removal by pressing eject, listening for eject motor noise and reaching in with tweezers or something to grip the CD NB you will scratch CD doing this. |
bsp128 Philips • MAGNAVOX++SYLVANIA+EMERSON+19MF339B F7 E • EL3302 Philips • Panel LG-Philips LCD LP171WP4-TLN1 0 [DS • bsb017n03lx3g rev2.2 Infineon • lch-2 NOKIA • COVER BELSON • Инструкция AVR-E200 DENON • Aeonic SuitcaseV AEONIC • Panel SHARP LM12S48 0 [DS] . Various •
