Fast50srmad
Posted: Mon Jan 02, 2017 8:12 am Post subject: |
A couple posts back _franky_ helped Sandra with only the same numbers I have supplied.
As a said I do not have access to the car at the moment. |
tmcu
Posted: Mon Jan 02, 2017 10:11 am Post subject: |
Fast50srmad wrote: | A couple posts back _franky_ helped Sandra with only the same numbers I have supplied.
The full serial number ( as the one supplied by Sandra ) is 14 digits , the one your supplied from the book wasn't 14 digits , that is why you were being asked for the serial number , if your radio is exactly the same model as Sandra's and the number you supplied is correct in the last seven digits then the code should be 4782 but it may well not be !
Otherwise you will need to remove the radio as suggested and post the 14 digit serial number that is stamped in the case , also the model number . |
Fast50srmad
Posted: Mon Jan 02, 2017 11:04 am Post subject: |
Okay thanks got it
BP248543743216
7642485510 |
Fast50srmad
Posted: Mon Jan 02, 2017 11:21 am Post subject: |
There is also these 2 numbers on it
No 92094577
92104224 |
tmcu
Posted: Mon Jan 02, 2017 1:35 pm Post subject: |
Fast50srmad wrote: | Okay thanks got it
BP248543743216
7642485510 |
Try 1302 |
Brittmaree
Posted: Mon Jan 09, 2017 5:12 am Post subject: |
Hi i need a code for my blaupunkt 2020
BP 0485 27897859
No. 92094577
Thank you |
masterskay62
Posted: Mon Jan 09, 2017 5:20 am Post subject: |
Brittmaree wrote: | Hi i need a code for my blaupunkt 2020
BP 0485 27897859
No. 92094577
Thank you |
Hi.
Try........2067 |
Grantlaubscher
Posted: Mon Jan 09, 2017 9:03 am Post subject: |
Hi I need a code for my Blaupunkt 2020
BP0485 1 7818588
No. 92 094 577
Thanks |
masterskay62
Posted: Mon Jan 09, 2017 9:33 am Post subject: |
Grantlaubscher wrote: | Hi I need a code for my Blaupunkt 2020
BP0485 1 7818588
No. 92 094 577
Thanks |
Hi.
Try......4869 |
Grantlaubscher
Posted: Wed Jan 11, 2017 6:20 am Post subject: |
You're a legend!!! |
