chrisjen0711 Guest
Posted: Fri Nov 21, 2014 3:56 pm Post subject: request service manual sony kv-sz25n60 |
Hi all
Need Service Manual for:
sony kv-sz25n60 made in malaysia
the stndby led flash 2 times.Hope this gives some idea and hopefully can narrow down to the problem with this error code.
Thanks for any help !
[/u] |
Posted: Fri Nov 21, 2014 7:30 pm Post subject: |
"When an error occurs, the STANDBY Indicator will flash a number of times to indicate the possible cause of the
problem. If there is more than one error, the Indicator will identify the first of the problem areas."
Diagnosis Item Description: +B overcurrent (OCP)
No. of times STANDBY Indicator flashes: 2 times
Probable Cause Location: • H.OUT (Q511) is shorted. (A board) • IC751 is shorted. (C/CV Board)
Detected Symptoms: •Power does not turn on. •Load on power line is shorted.
Elektrotanya has manuals for your CHASSIS. _________________ You're over there, I'm over here. |
SMMUyco Guest
Posted: Fri Jul 10, 2015 1:48 am Post subject: |
Help same TV . mine has black wave vertical line in both end |
Logik repair tips Logik • B53-0084-00-PCB Kenwood • 486 901 01D Keithley • aspire 3000, 3500, 5000 series service g • SOM+PHILIPS+FWM+416 Philips • NPE3-027 NOKIA • RIGOL DG2000 user 2527s Rigol • Fluke-Test-Tools-2012-2013 Fluke • • idc a09 blaupunkt •
