midix Guest
Posted: Fri Feb 17, 2006 5:52 pm Post subject: Old monitor turns itself off even when disconected - help! |
I have an old EIZO 14'' FLEXSCAN 9060S monitor and I need it to be working at least for a month. At first it worked fine although was second hand already. But then it started switching itself off after 10 minutes or so. I decided that I have nothing to lose and started adjusting SUB H. SIZE inside of it (because I noticed that the iamge on the screen has black sides, it is not wide enough). And after that it worked fine for 2 months. Then I bought a new one and put my EIZO away in a bit cool place (but not wet). After 2 years I need it again but now it turns itself off after 4 seconds or so no matter if I connect VGA to PC or no. With SUB H. SIZE I can only change the time to 3-5 seconds and nothing else. Other regulators do not help. What could have gone wrong, any ideas?
It turns completely off, the screen goes black and power led turns off and this little noise inside of it (you now, all CRTs have that noise) turns off too. When I disconnect it from the power and count to at least 5 then turn on, it works again for 4 seconds.
I have an experience with repairing radios and cassette recorders but I am a bit afraid of monitors (because of a high voltage) although I could replace any component if only I knew which one is faulty.
Thanks (at least for reading this nightmare). |
Posted: Fri Feb 17, 2006 6:40 pm Post subject: |
It sounds like it could be a capacitor related problem. Do you have an ESR meter to test them with? |
midix Guest
Posted: Fri Feb 17, 2006 7:44 pm Post subject: |
No, I don't have it. But thanks for the idea. I once had a PC motherboard which has strange behaviour but that was simple - I saw the faulty capacitor, it was blown up. And after replacing everything was OK.
Maybe the electrolyte in some capacitors have gone wrong while the monitor was in coldness...
Is there any other way to check capacitors without ER meter or to find the faulty ones? And where they could be located? I cannot find EIZO schematic diagram. |
Posted: Sat Feb 18, 2006 1:09 pm Post subject: |
It is not easy. A capacitor usually makes your meter needle move up, then slowly down as it charges on the ohms scale. A shorted capacitor may read low ohms and an open capacitor may not read much.
Very gently move each capacitor sideways, it should be firm with 2 legs, very occasionally you will find one of the legs not connected even though the meter said it was connected.
If you suspect a capacitor, solder another of equal or greater voltage across it and try it again.
It could be shutting down due to excessive voltage or any number of things. What happens when you heat it up with a hair drier or put it near a heater? |
SCHEMATIC DIAGRAM Rolsen • rrv2166 vsx-908rds Pioneer • TX-28WG25C Panasonic • b pcb 1 panasonic • 198401 10 Machines IBM • gallien-krueger-2100-amplifier-schematic • tc6320 Supertex • ssg4505 Secos • bcr505 Siemens • 5714 - manual de servicio panasonic •
