different type floor maintains ways
xiao1236
PostPosted: Thu Jun 22, 2017 7:08 am    Post subject: different type floor maintains ways Reply with quote
Nowadays, wooden floor has begun to walk into an innumberable families, the ground of predominate decorates material. Real wood floor, solid wood joins floor, aggrandizement floor, bamboo floor board is our common floor type, network of Chinese wood floor is small make up remind here: Floor type is different, its floor maintains maintain pattern disparate also, we should be distinguished treat.
Real wood floor maintains watchful item
Although real wood floor does not involve agglutinant in manufacturing technology, won't produce formaldehyde consequently, suit the family that there is sensitive multitude in the home very much. But real wood floor is very fragile, it is floor category in do the hardest. To prolong the life of real wood floor, maintaining go up to must make great efforts one time. Real wood floor does not like humidity to cross big room, like dry, bright and clean, if have water above, answer to use dry cloth blot in time. To maintain real wood floor beautiful extend lacquer range service life, need is annual and cerated maintain twice.
Solid wood adds up to a floor to maintain watchful item
Generally speaking, solid wood joins a floor board be able to bear or endure ability in swimming is poor, unfavorable wipe with wet cloth or water, lest lose luster, this kind of floor is done rise to still be simple. Clear daily a little some are exquisite, need to use twist dry cotton mop to wipe, if touch stubborn besmirch, the reoccupy after applying neuter and clean dissolvent to wipe twists dry cotton mop to wipe. Anyhow, water is the deadly injury that solid wood joins a floor board.
Aggrandizement floor maintains watchful item
The one big advantage of aggrandizement floor is easy maintain, the 3 oxidation of its surface facing of 2 aluminous wear-resisting makes bilge and dust are not touched completely on floor. But its be being returned basically is woodiness material, aggrandizement floor often should maintain Gan Shuang and cleanness, cannot rinse with water directly. The daily attention of aggrandizement floor can use cleaner aspiration, with damp-dry pull cloth to wipe, the attention avoids floor bureau the ministry is long-term and soggy. If the floor touched oily be soiled and bilge, want to be clear about in time, had better use the cleanness of special floor board with floor form a complete set to protect fluid to clean.
Bamboo floor maintains watchful item
Bamboo floor is very a kind of floor of environmental protection, using natural data as a result of it, so extremely easy be deceived awaits the effect of dry humidity, some are flimsy, need caresses ability carefully to prolong service life. In daily use process, should often clean floor, maintain the clean sanitation of the ground. When cleanness, can mix dirt with clean broom first sundry sweep clean, next the dishcloth that reoccupy twists dry water is wiped artificially, if the area is too large when, can wash cloth mop clean, hang a dry water again, with will pull only area. Cut cannot bathe, also cannot clear with damp dishcloth or mop. If have hydrous material douse,be at ordinary times when the ground, should wipe with dry dishcloth instantly dry. If the condition allows, OK still and removed period of time hits a floor wax to be opposite in order to strengthen the protection of the floor. If paint face has damage, can oneself fill to go up or ask manufacturer to repair with common varnish.
wpc decking importer
outdoor bench slats replacement wood product
pressure treated tounge and groove wood for outdoor use
waterproof interlocking composite decking
