sstn Guest
Posted: Thu Oct 07, 2004 5:00 pm Post subject: RCA F36669 36" Direct View Television |
Have a RCA F36669 36" Direct View Television I purchased used. Problem is that the Cable/Antenna connection in the back is broke off. It needs a whole new part. Is it possible to weld off old part, and weld on the new part, with having it work, and no problems? Is this fairly easy, or should it be taken to a professional? Also if taken to a professional about how much will it cost?
Any help, or suggestions are appreciated. |
MAC.T Guest
Posted: Sun Oct 10, 2004 5:17 am Post subject: |
it is possible to do that it is not such a big job if you know what you`r doing for the price it is about 1 hour labor |
GreggW Guest
Posted: Sun Feb 05, 2006 9:10 am Post subject: |
Does anyone know what the part is? I have the same problem. |
guest Guest
Posted: Tue Feb 14, 2006 9:51 am Post subject: cable connector broken |
the cheapest solution would be to connect a vcr to the set thru the a/v jacks and use the vcr to change channels. |
tip3055 Inchange Semiconductor • cp 600 dlp 32d1lps 158 Daewoo • Wren VI HH Brochure Nov88 cdc • NP6012PC CANON • PHILIPS Q522.1E LB CHASSIS LCD TV SM Phi • Panel SAMSUNG LTA320AA05 0 [DS] . Variou • BENQ- E61 1 siemens • B53-0138-00-TXT Kenwood • 2sd2120 Sanyo • VZ8 Chassis MITSUBISHI •
