phaedrus_Q Guest
Posted: Mon Mar 06, 2006 10:42 pm Post subject: Changing sound channel to 6 from 5.5 for Proline 418B/TX807 |
Hello,
Have a UK TV in Australia, which doesn't recieve sounds as the sound channel is set to the UK standard. Can I change a component on the board to change the sound channel so it works? I was hoping that there was a dip switch, but no such luck. If I can't do this for pennies, the TV will be thrown away.
Thanks. |
baskarz Guest
Posted: Fri Mar 24, 2006 4:50 pm Post subject: |
yes indeed you can replace a part and get your sound.
in the IF stage (near tuner) there will be 2 ceramic filters with a "6.0" on them. if you know what you are looking for, will be easy. usually 3 legged ceramic capacitor looking devices.
replace them with same things labelled "5.5" (from scrapped AUS tv)
these will change the sound IF from 6MHz to 5.5MHz (AUS standard) |
V9079-90001 V9079B TD-SCDMA User 2527s a • 058ats LG • [radial] MIN-13 Series Joemaster • aj-15 HEATHKIT • s a4 t panasonic • Compaq Armada 100S and COMPAQ • cd74hc166 Harris Semiconductor • [bi-polar axial] RMN Series Richey • bsc030n03msg rev1.16 Infineon • RCD 300 PASSAT B6 grundig •
