Monitor schematic Nokia 446Pro / 446F
Torno
PostPosted: Thu Oct 21, 2004 10:42 pm    Post subject: Monitor schematic Nokia 446Pro / 446F Reply with quote
Hi all!
I need the schematic (or sm) over Nokia 446Pro/446F monitor - thank´s for any help on item!!
/Torno
howly d
PostPosted: Thu Nov 11, 2004 9:04 am    Post subject: Monitor schematic Nokia 446Pro / 446F Reply with quote
you're not having problems with brightness, are you?
alphacygni
PostPosted: Thu Nov 25, 2004 7:30 pm    Post subject: me too Reply with quote
i need these schematics, too... i have a bad trouble on the power supply of a 446PRO and i would like to fix it Sad
PostPosted: Sun Jan 16, 2005 5:05 pm    Post subject: Re: me too Reply with quote
How do you remove the case of this monitor? I can't get it open Sad Please if anybody know this let me know. I seem to have a bad contact but if I can't get the case of the monitor off i can't repair it Crying or Very sad
you can mail it to me on the following email adres jverschaeve@vt4.net
gabyh
PostPosted: Sat Aug 20, 2005 10:33 am    Post subject: nokia 446f Reply with quote
i have a shematic and service manual for this model but ai need 445za chassis 445z
guest
PostPosted: Sun Feb 12, 2006 2:13 pm    Post subject: i have problem with the brightness on my Nokia 446pro Reply with quote
any hints or common foult?
Please help me
smid
PostPosted: Wed Mar 01, 2006 6:10 pm    Post subject: Re: Monitor schematic Nokia 446Pro / 446F Reply with quote
Hi, I have problems with brightness on Monitor Nokia 446Pro / 446F. Sad
Can I repair it ?
bb
PostPosted: Fri Mar 24, 2006 10:18 pm    Post subject: Reply with quote
Same here. The Monitor has gradually become too bright. Black is grey even with brightness set to zero. Anybody know hos to fix this?
sk
PostPosted: Sun Aug 05, 2007 1:31 pm    Post subject: Reply with quote
Hello, you cannot fix it properly thru the service menus. Luckily I've found a way to fix the brightness problem in my 446Pro from a finnish electronics forum. There are three black screws to adjust inside the monitor on the bottom left corner. Only two bottom screws should be used. The bottom screw is for adjusting the brightness and the middle one is for the focus. The screws have text Screen and Focus written beside them, respectively. The screws are near some transformer unit and they can be reached without opening the covers thru the holes in the covers. You only need a flat screwdriver long enough.
But at least in my case the screws were so covered with the dust and I could not spot them without opening the covers first. I recommend you should open the covers first time as well and give a proper cleaning inside with the vacuum cleaner. It is also much easier to find the screws then.
If you decide dive inside, first remove the plastic cover. Open two screws in the front lower corners. Then push with the flat screwdriver thru two holes located in front top corners to release the locking levers. Next you should remove the back aluminum casing to get inside. It has many Torx screws to open first, but after that it is easier to find the right screws to make the adjustment. When adjusting keep the monitor on and connected to your PC, but beware of the electric shock! Do not try to do any of this, if don't know where you can touch inside the monitor and where you can't!
I also used Nokia Monitor Test to get the best results. Black is now black and the brightness can be controlled again. Very Happy
