Rouslan N. Guest
Posted: Sun May 28, 2006 12:01 am Post subject: Basic questions about TV |
I am repairing a TV for the first time and have no experience\knowledge.
-Is there really X-radiation present when I turn the TV on, should I worry about this?-I read it on a label on the CRT
-Is it dangerous to touch the metal casing of the CRT?-Isn't that the High Voltage output?
I got a response that I have bad B+ regulation after I posted the topic "Weird Problems with TV." |
Posted: Sat Jun 03, 2006 12:39 am Post subject: Re: Basic questions about TV |
Rouslan N. wrote: | I am repairing a TV for the first time and have no experience\knowledge.
the answer to you questions are simple, Most television especially The type with Crt's put off some but very miminal amount of xray radiation, This evolves for the high voltage produced in the tube, But nothing to worry about, The Metal Casing is Ground, All televisions have X-ray protection, so if the high voltage exceeds the limit of the tube , the set will go into failsafe mode, meaning it will shut down the horizonal circuit used to drive the high voltage circuit, Never touch the RED Wire running form the flyback to the top to the crt as this is High Voltage a typical 20" television can have as much as 20,000 volts to light up that tube. Most sets today discharges this voltage to dagg Ground when you turn the set off, But always be safe and use a High probe to discharge the tube before touching the cap at the top of the CRT.
If you have a brighter screen then normal your B+ maybe to high, But usually in this the regulation feedback Pulse will shut down the Regulator and shut off the set,Measure the collector voltage on the horizontal output transistor sould be about 130V-135V and higher then this the set will go into failsafe. If too high Replace the main B+ REgulator and current liminting resistor associated with the regulator..
Hope this helps
[email protected] |
Posted: Sat Jun 03, 2006 12:42 am Post subject: Re: Basic questions about TV |
I got a response that I have bad B+ regulation after I posted the topic "Weird Problems with TV." | |
KA5Q SERIES FAIRCHILD • 22rh781 Philips • 2sc5075 Toshiba • hfe lafayette la-25 en Lafayette • ml 320, 321 oki • 20LCD MCU BEKO • Allocchio Bacchini 411 ALLOCCHIO BACCHIN • hfe pioneer vsx-5500s 5400 service Pione • Statement.mesa Sep78 xerox • KM-C2520 C3225 C3232 3050 4050 5050-IG-D •
