Luti02 Guest
Posted: Sun Nov 07, 2004 10:02 pm Post subject: :( [b] Help me a bout C44 [/b] |
how i can find tools for epson c44 adjust cartridge ? [/b] |
cragdor
Joined: 25 Feb 2005 Posts: 1 Location: Aberystwyth, Wales
Posted: Fri Feb 25, 2005 2:42 pm Post subject: |
Hi mAte i think i need this program as well and i have found a site that. Sells the programers but with one exceptiong it does the c41/42/43 i blieve it would also support the 44 but i'm not sure. the web site is. http://www.2manuals.com/ This site also has a repair manual for said printer but it again charges for that as well. Hope this helps
My problem is that i have recently stripped and cleaned two printers the first was a epson 810 which had been put in storage for a year. I cleaned out the heads using ink fulsh and when u runn the cleaning cycle u can se the in flow through the rubber tube at the side.(I have run a intial charge) but when it comes to print out anything including a nosel check i get nothing Not even a blot of ink. I feel that perhaps like the c40 this printer has a onboard Eprom which is stopping the head from printing. Why i don't know.
The second printer is a c44UX this printer was blotting ink all over the place after stripping the printer down i found the problem to be the funnel for catchig the in had not come off its form correctly and that there was no hole going throught to the pip underneath. (A small ammount of plastice was blocking the one end) This ment that every time the print head went over to the park possition it was being smeared with old ink. I fixed this and flushed out the head. Again using the SSC service Utility to intialy charge the had. This is also suffering from the same problem as the previous printer however its alot less noise now the pump can suck the ink through and not suck against a vacum.
Please if anyone has this Eprom programer or nows how to fix abouve problems reply to this post. _________________ Argh This Epson C44 and Photo 810 |
Posted: Fri Feb 25, 2005 10:55 pm Post subject: |
there is a programme called sscserve which is quite good.what can happen if you keep using head cleaning a count is kept after a time it reaches a number and stops the printing the theory is that the pad were excess ink is collected is full sscserve lets you reset the count |
irfp23n50l sihfp23n50l Vishay • 2n6717 NO • MVH-88UB Pioneer • 42LM580S, 580T, 585S LG • hfe t-4140 service ONKYO • Panel CMO M190E2-L01 2 [DS] . Various • DSO400u Gould • HFP0274 Sony • TX-32PL1 Panasonic • manualst Philips •
