mdm Guest
Posted: Sun Jun 18, 2006 2:31 pm Post subject: compaq evo n600c power jack |
| I've downloaded and looked at a manual for the Compaq Evo N600c, but there is nothing in there about replacing the power jack. Can anybody help me here - I'm hesitant to just open up the system and start poking about before I know how to properly replace the power jack. Can anyone give instructions please? Thanks. |
Posted: Tue Jun 20, 2006 6:03 pm Post subject: |
| What do you mean by the 'power jack'? |
mdm Guest
Posted: Wed Jun 21, 2006 11:18 am Post subject: compaq evo n600c power jack |
| power jack, on the back of the laptop where the power cord plugs in. I already have the part, just don't know how to replace the old one. |
Posted: Wed Jun 21, 2006 5:42 pm Post subject: |
An older Compaq I dis-assembled had the power socket as part of the power supply. To remove the supply was just a matter of taking all of the screws out and dis-assembling the laptop. The power supply was harder to dis-assemble and required desoldering. Keep the screws in order and take special note of any that are longer or shorter.
The new socket may require soldering.
Let us know how you go.  |
mdm Guest
Posted: Sat Jun 24, 2006 10:58 am Post subject: compaq evo n600c power jack |
| Hi, thanks for the info. I'll let you know how it goes - I have to get my hands on a soldering iron, and will probably get it done in the next couple of days. Cheers! |
mdm Guest
Posted: Sun Jun 25, 2006 3:36 pm Post subject: compaq evo n600c power jack |
Turns out that I have the wrong part! I have to re-order and try again. Thanks for the suggestions, I'll post again when I do get the thing fixed! |
skijump Guest
Posted: Thu Jul 13, 2006 10:46 pm Post subject: |
When you open up the laptop, you will find that power jack (DC socket) is situated at the back end of the board. This is held in place by 3 solder joints going directly through the board to the underside. De-solder very carefully these 3 points, using a suitable electronics soldering iron and a solder sucking pump. Clean the holes and area well and then offer up the connector jack to the board. You may have to heat up slightly from behind on the underside of the board to allow the new pins to pass through the board. Gently apply a small dab of solder to each of the 3 pins on each side of the board and then re-assemble
job should be a good un after that |
www.lipetsk.name
boom.bg : аукцион -
MondeTech
SEO -
Онлайн поща -
