creieruu Guest
Posted: Mon Nov 15, 2004 12:03 am Post subject: Sanyo Chassis EB4-A28 Model CE28DN3R |
hi i need a service manual for Sanyo Chassis EB4-A28 Model CE28DN3R |
Bernard
Posted: Fri Jun 02, 2006 5:58 am Post subject: |
Hi there,
Did you find a service manual with circuit diagram for this model?
I am looking for exactly the same one! Surprise surprise.
I have a curious fault with this set, initially as you do, I thought I had a tuning problem (When first switched on this sets tuning drifted all over the place but eventually settled down)...well as you do, I traced the 33 volt tuning voltage back and changed the 33 volt regulator IC.
Problem solved ...no chance........well sort of....BBC1, BBC2, SC4C great or nearly great...still seems to be mistuned slightly as there is the usual sort of just off tune noise on the sound...picture ok. ITV though when initially selected is black and white then the tuning drifts right off ...I think but not sure but the AFT is right off tune. There is a -10 displayed in the bottom right hand corner of the screen.
To make matters worse after the set is on a while it now trips out..can be changing channels or when and where it likes. I am not sure that I may have disturbed something else and I do need to check the supplies but if you or anyone else has any ideas then I would be most grateful. Plus a circuit diagram would be most helpful.
Thank you for your time and trouble in advance, looking forward to your reply ....even if it makes me look like a dimwit!
Bernard |
8100b Fluke • download1 Pioneer • Б. Боровски и др. - Микропроцесори - уст • daewoo cp-002 Daewoo • DVP3120 philips • 657U Philips • std90n03l std90n03l-1 ST • 4350 HP • adverts University • •
