NickTG
Posted: Sat Jul 08, 2006 6:37 am Post subject: Sony KV-29X5D problem.5 flashes at sw on |
I have the following problem.When i switch on the tv the picture remains dark with sound, for about 2 mins.During that period the LED flashes 5 times every 2 secs.This happens 24 times.5 flashes-2 secs pause,5 flashes-2 secs pause...
There is also a screen problem.Objects and letters have a slight shadow to the right of them (which in most cases is red).Screen has lost it's clearness.
What can be wrong and what can be done about it? |
EDMEIZTER Guest
Posted: Sat Jul 08, 2006 12:19 pm Post subject: 5 BLINKS SONY ERROR CODE |
PROBABLY PROBLEM WITH VIDEO OR IK. TRY AND SEE IF ADJUSTING SCREEN SETTING SLIGHTLY MAKES A DIFFERENCE. |
Posted: Mon Jul 10, 2006 4:14 pm Post subject: |
5 flashes is an AKB error which means the tv cannot set the grey scale correctly, unfortunately with the other symptoms you mention it sounds like the crt is on its last legs, adjusting the screen voltage may give a temporary fix but only real cure is replacing the crt which would be costly |
Panel CHIMEI INNOLUX M270H5-LA2 2 [DS] . • ixbk75n170 ixbx75n170 Ixys • Yamaha • PCG-GR150 (K), PCG-GR170 (K) Sony • LCT-2662 Akai • English 2014-03-16 PDF 2.21 MB 5991- • KRC-2902 Kenwood • trouble EP2050 116 Minolta • block panasonic • hgtg20n60b3d Fairchild Semiconductor •
