nowrob3
Posted: Mon Jul 10, 2006 3:11 am Post subject: gb5108 apex horizontal lines |
i have had this apex gb5108 tv for serveral years, and just a few weeks ago all the color on the tv has become 1 horizontal wavy line. i can still heard sound. i have read serveral other places blame it on a semiconductor. what could it be? i dont kow where i would buy a semiconductor. any help i give thanks to. |
eltech64 Guest
Posted: Thu Oct 05, 2006 2:18 pm Post subject: Apex GB5108 |
Sounds like you have a vertical failure. I'm assuming you mean the set set has 3 colored lines running horizontally across the screen which indicates a vertical circuit failure. The vertical IC is a semiconductor, however additional parts need to be checked. If you cannot locate this part on the chassis you may want to turn this over to a more experienced person. |
ServiceDude Guest
Posted: Wed Sep 05, 2007 7:22 pm Post subject: Apex GB5108 |
This a easy problem to fix. You say it has a thin line accross the center. Change out IC N301 it is a TDA8351 and it crosses to a NTE7156. Also change R370 it is a 1W/1 Ohm Oxide Metal Resistor
R371 it is a 1W/33 Ohm Oxide Metal Resistor and
R380 it is a 1W/1 Ohm Oxide Metal Resistor.
Be very careful not to short any pins on chip with solder when re-soldering, double check all solder joints for shorts and correct before turning set on. This should fix your problem with the vertical collapse. |
Posted: Thu Sep 06, 2007 4:04 am Post subject: |
In other words, your vertical IC crapped out. |
CHRISTIE N. CROCKER Guest
Posted: Fri Aug 01, 2008 5:33 pm Post subject: Re: gb5108 apex horizontal lines |
WOW! I AM HAVING THAT EXACT SAME PROBLEM... I WOULD LIKE TO KNOW THAT ANSWER TO THIS AS WELL. nowrob3 wrote: | i have had this apex gb5108 tv for serveral years, and just a few weeks ago all the color on the tv has become 1 horizontal wavy line. i can still heard sound. i have read serveral other places blame it on a semiconductor. what could it be? i dont kow where i would buy a semiconductor. any help i give thanks to. | |
Posted: Fri Aug 01, 2008 5:37 pm Post subject: Re: gb5108 apex horizontal lines |
CHRISTIE N. CROCKER wrote: | WOW! I AM HAVING THAT EXACT SAME PROBLEM... I WOULD LIKE TO KNOW THAT ANSWER TO THIS AS WELL. nowrob3 wrote: | i have had this apex gb5108 tv for serveral years, and just a few weeks ago all the color on the tv has become 1 horizontal wavy line. i can still heard sound. i have read serveral other places blame it on a semiconductor. what could it be? i dont kow where i would buy a semiconductor. any help i give thanks to. | |
Look 3 posts above this and there's your answer. |
