Posted: Fri Jul 14, 2006 8:23 am Post subject: Nikon Coolpix 880 Battery Cover |
Hi
How do you replace the battery cover on the coolpix 880?
It must be simple. But do you have to remove the bottom of the camera? I am guessing that the hinges must slide to one side or something?
Thanks
Juan javascript:emoticon('') |
dlundmark Guest
Posted: Mon Oct 15, 2007 8:31 pm Post subject: Re: Nikon Coolpix 880 Battery Cover |
[quote="Anonymous"]Hi
Thanks
Juan javascript:emoticon('')[/quote]
Hi.. It is quite simple.
Take the screws out of the case, but be sure to make a drawing ,as I do, of the camera...for instance of the bottom, and the sides. Then make a line up or mark where each screw is. As you remove the screws, tape each in place or ,if only for a short time, you can roll scotch tape together and stick the screw to the corresponding place. That way you will know where each screw goes. Be sure to do something like this, because the screws on this camera vary, and the wrong screw in the wrong place can damage one of the boards or mechanism.
You will see how to replace the battery door when you crack apart the case.. always work slowly, because there are nibs which lock the case to each side... remove firmly, but slowly.
thanks, |
Posted: Mon Oct 15, 2007 8:35 pm Post subject: Re: Nikon Coolpix 880 Battery Cover |
dlundmark wrote: | Anonymous wrote: | Hi
Thanks
thanks, |
BTW ... If you are only replacing the door cover, then all you have to do is remove the two screws in the cover and replace the old one with the new, then replace the two screws... |
8310 nokia • TAF650ESD Sony • 22RR482 Philips • VA912 SM 1a Viewsonic • bd724 Inchange Semiconductor • CX-JN5-1[1].1.part1 AIWA • BM1912RAM08-D Model DM10 Data Sheet Marc • hfe hr-895 schematics CARVER • ipd50n04s4-10 ds 1 0 Infineon • MRC-A120 2018 Motronix •
