cgreer
Posted: Thu Jul 20, 2006 1:41 am Post subject: rca tv model F27242GY |
I need to replace the CATV connector on this TV. Any help would be appreciated. Thanks |
alltronix
Joined: 14 Mar 2005 Posts: 25 Location: Lincoln Nebraska
Posted: Thu Jul 20, 2006 6:52 am Post subject: |
you need to remove the shield on the bottom of the tuner section. if you still have the broken rf connector you can put it back on and just repair the broken lead if it is not broken off to far inside. If you need to get a new one, try a local tv repair shop to get one. should only cost 3 - 6 dollars. after fitting the connector in the hole just get a hot soldering iron and solder all around the edges. you might want to screw a cable on it before soldering it to keep the plastic from sealing the small center hole. The circuit trace on the board might be torn loose also and you will have to put a small jumper on it. Solder the shield back on and you should be back in business. Good Luck |
HL35AV TX-15TA1C panasonic • vf17 fp17 HP • hfe cv 1500 rc en de fr DUAL • mbp15 mid09 apple • PowerBook G3fw-dvd-cip apple • KRFV5020, 6020, 7020 Kenwood • 601106 03-09 panasonic • Satellite 3000 Series Toshiba • powermac g5 late2005 apple • HP 11716C OPS NOTE Agilent •
