martin LP Guest
Posted: Sun Jul 30, 2006 5:30 am Post subject: sony kv-27 trinitron power issue |
I have this TV where there is no indication of power on the front panel and the power will not switch on. I have checked the internal fuses and the 120 V AC to inside the chassis. No problems there.
I think there should be some 5 volt supply always available to run the standby circuitry but cannot seem to isolate it on the power supply section of the main board. Unfortunately I am not able to find a schematic.
I do see that the connector from the control card to the main board has a connector where one pin is labeled 5 V standby. The connector from the control card to the front panel also has a 5 V standy pin. There is no voltage on this pin.
Any suggestions? Or does anyone have a service manual/schematic for this or similar TV?
Model KV-2?V55 (can't read the label. probably KV-27V55 since it is a 27 inch TV.
Thank you
Martin Perrine |
daved Guest
Posted: Mon Jul 31, 2006 1:29 am Post subject: |
try here you may have some luck
manuals.electromaniacs.com/
Dave |
Posted: Mon Jul 31, 2006 1:41 am Post subject: |
Check/Replace Q601,Q602,R607,C610/.22mf,Q591 |
martinlp
Posted: Fri Sep 08, 2006 10:06 am Post subject: power problem for kv27 |
Hi Minnie
You mentioned several specific part numbers. Thank you very much I'll look into that. Do you have a schematic for this TV? Or do you know if there is a very similar set that may have a schematic available.
Sorry it took me so long to get back to this. |
Posted: Mon Sep 11, 2006 5:09 am Post subject: |
Check R607 and see if it's open. It's a .10ohm resistor/fuse. |
Panel COC PM42H3000 0 [DS] . Various • Chassis 512 Telefunken • 2680s RM392 schematics v1 0 NOKIA • M-14 Grundig • ntd4858n ON Semiconductor • TVP0247 Sony • MZ-E300 Sony • www.thinksrs.com-PERF10c Stanford Resear • SDI PDP REPAIR MANUAL S42SD-YD09 S42AX-Y • 11-nhm-8nx-schematics NOKIA •
