polaret
Posted: Tue Nov 23, 2004 10:44 pm Post subject: philips anubis |
Hallo i have a MODEL 20PT 135A42 (ANUBIS AAC)the problem is that doesnt stop when tuning any help? |
sorin_tv
Posted: Wed Nov 24, 2004 4:12 pm Post subject: dump for eeprom |
hello
try to change the eeprom dump or enter to service mode to adjust the agc value |
Posted: Fri Dec 03, 2004 8:36 pm Post subject: Re: philips anubis |
polaret wrote: | Hallo i have a MODEL 20PT 135A42 (ANUBIS AAC)the problem is that doesnt stop when tuning any help? |
Most likely the AFC coil causes this problem.
If you remove the TXT board you will see a shielded area underneath it.
When you remove the cover you will see a coil which has a red inner area.
I don't know what value it is, but you ajust it a little bit you will probably have a working tv.
It is also possible that the Identification line is not working properly because the TDA 4555 ic is faulty.
But in most cases it has something to do with this coil. The ic I mentioned is in the same area as the coil.
Greetings
Jeroen Hartman
TV engineer |
DiamondMax 22 SATA II maxtor • toshiba d-vr7kc sm TOSHIBA • 2MD-001 Kyocera • LeXfiles SXFun6in1v1.2 Aug2004 Philips • AVR3801 Denon • R3265A R3271A Spectrum Analyzer Vol II S • AXIAL TAPING, Cut Lead & Lead Forming an • pdtc144e series Philips • General EP4000 096 Minolta • LC7.2E LA LCD TV.part06 Philips •
