Backlog
Posted: Wed Aug 23, 2006 1:47 am Post subject: Sony SSM-14N5E CCTV Monitor |
Hello, I have a Sony SSM-14N5E CCTV monitor in witch i need to adjust RED-gain.
Tube seems OK, though little worn (slighly out of focus, but not bad). Red is present only very low, adjusting it should be enough. But as is usual with these newer (2001) Sony;s there are no pots inside to play with. So the qestion is: can i adjust the colours in service menu (and if so, how?) or is this done via DAS (digital aligment software) in which case i can just adjust it with a hammer
Any help is greatly appreciated! |
tkg Guest
Posted: Wed Aug 23, 2006 2:30 am Post subject: yes you can |
since you have that problem your best option is put the tv on for while check the main IC to see if its running hot if so change if not, go to maine menu from your remote look for color adjusted from there... |
Backlog
Posted: Wed Aug 23, 2006 2:43 am Post subject: |
Thanks tkg for fast reply!
No remotes here I guess i could have been clearer... The unit is a surveillance monitor with just 4 button interface. Pretty much like normal TV;s though. I suspect that this is a case of normal wear (3~4 years 24/7 on). But i´ll test it with a known good chassis. |
Award-Sessionsb100-sch AWARD SESSION • f100main LG • PET-portable DVD Training Manual.part7 P • p pf c37 panasonic • thinkpad x100e x120e IBM • AKD-0275RDS_0285RDS Daewoo • AMSYS29 uProgSuppSW AMD • 1-npe-4-foreword NOKIA • www.thinksrs.com-SIM925c Stanford Resear • PHILIPS+FW-C99 Philips •
