CM08 Guest
Posted: Thu Aug 24, 2006 6:02 am Post subject: Sanyo CE32WN6F-C-01, chassis series EB7-A32, flashing lite |
they just don't make them like they used to. I have a 2 year and 2 weeks old sanyo CE32WN6F-C TV, chassis series EB7-A32. Left for vacation everything worked fine. I even went to the effort of unpluging TV. Upon return plugged TV in, turned main power switch on, all looked normal as the power lite came on. As soon as I tried turning the TV on using the remote, I heard the usual TV tube noise and then nothing. All I get is a blinking lite and a constant low tic, tic, tic from inside. Try turning on again using the remote, the flashing lite turns off as the TV seems to try and power up and again nothing but the flashing lite and the ticking noise. Turning TV off completely using the main power switch and then back on just repeats the pattern.
Looked for obvious signs of burnt caps or resistors but all seems normal. Also tried resoldering some joints and checking some resitances based on comments from this site related to similar models and reported problems, but I cannot be sure that the resistor numbers I checked are the correct ones. No change. Any help would be appreciated along with service manuals for this model if possible. Thanks |
Posted: Thu Aug 24, 2006 8:52 pm Post subject: |
It sounds like a classic example of electrolytic capacitor failure. Try checking/replacing all of the filter capacitors and replacing all of the electrolytics in the powersupply. Maybe they used only 85 degree capacitors like they used to? If you are lucky and have not done more damage by poor voltage regulation this may be all you need.
Let us know of your outcome. |
cm08 Guest
Posted: Fri Aug 25, 2006 5:48 am Post subject: |
thanks for the reply. I looked at the electrolytic caps again and only one seems to have some minor distortion (bubbling) on the head. It is a 200V 220uf and it is an 85 deg cap. The number of the cap on the board is C642. Unfortunately I am not an expert in electronics and am limited to part replacement and tests. I do no really know if this particular cap, if defective, could cause the problem so I will likely replace it. What temp ratings are being used now?
Any added comments or help will be appreciated. Does anyone have a schematic and service manual? I would like to order replacement caps but many others are more difficult to read and it would help. A trip to the electronics store is in order.
Thanks again |
vgn-UX Sony • DVDR985 Philips . Various • R30, R50, R70 Sansui • B100 032 CANON • h-810 hunday • hfe pioneer sx-580 service Pioneer • TP20DC,TP30DC TOPPOWER • 22sc4635 2 • hsu1 NOKIA • bcr169s Siemens •
