briancp
Posted: Sat Oct 07, 2006 10:30 pm Post subject: NEC Plasmasync 50 MP1 |
When turning the set on I get the usual click, followed by popping sounds. No display (altghough the fans work) then the unit will shut down after 10 or so seconds and the green/red light will flash as the system enters self protect mode.
I’m guessing the popping sounds are the relays on the power supply pcb that are attempting to latch but are failing due to problems elsewhere.
If I use input select and power button for a hard reset the unit will usually fire up after a couple of attempts ie after it warms up. Or I sometimes just get the popping sound, turn off, try again and third time lucky the relays will latch and viewing is fine after that. Problem started about a week ago and has got more frequent so something is obviously detonating
Any one got any ideas? |
PCZ0903046CE panasonic • dsd1406006ce panasonic • vl-wd250e Sharp • H500 ZENITH • khb9d0n90n1 KEC • DV-260-S Pioneer • MQMSH0011DG151214REV1 AX800 Series SOS O • PRX Series Interface PCB Parts List JBL • service Daewoo • PM300 pwr amp Carver •
