TKOCHAMP
Posted: Tue Oct 31, 2006 10:06 pm Post subject: Audio/Video control center / dvd player |
To anyone:
I have a Sony 'Digital Delayed Surround' Audio/Video Control Center. Whenever I turn it on, it immediately stops and displays PROTECTER, without even being attach to other equiptment (ie: speakers, VCR, DVD).
If anyone has any information on how to correct this, it would be greatly appreciated. Thank you.
P.S.
I have a Norcent DP300 DVD Player, which is malfunctioning, the screen colour turns black and white, and skips up and down, continuously. Again if anyone has any information regarding this problem as well, it would be highly appreciated. Thank you for your time. |
Posted: Wed Nov 01, 2006 9:25 am Post subject: |
without knowing the model number of your sony system it is impossible to give more accurate advice than that the audio outut stage has a fault, probably a s/c output ic or transistor, if output stage is ic based removed the output ics one at a time until unit will power up correctly. if transistor based check each transistor indvidually out of circuit and remember if amplifier uses a dc coupled output stage more than one transistor will have failed. |
TKOCHAMP
Posted: Sat Nov 04, 2006 7:06 pm Post subject: |
gary wrote: | without knowing the model number of your sony system it is impossible to give more accurate advice than that the audio outut stage has a fault, probably a s/c output ic or transistor, if output stage is ic based removed the output ics one at a time until unit will power up correctly. if transistor based check each transistor indvidually out of circuit and remember if amplifier uses a dc coupled output stage more than one transistor will have failed. |
Thank you ,the model number is STR-AV 920 hope this can help ,Thanks again . TKO |
Posted: Mon Nov 06, 2006 9:10 am Post subject: |
as it is a north american model i have no info , sorry cant help beyond earlier post. |
carcus
Posted: Mon Nov 06, 2006 9:49 am Post subject: |
if it may help all the sony surround sounds i have looked at were Whenever I turn it on, it immediately stops and displays PROTECTER
have always been dry solder joints on the main audio output PCB ...
when ive removed the main board and inspect it under a magnifying / lamp they are covered in dry joints all around the output components, the plug / socket connectors and most of the big electrolytic capacitors too .... so this could possibly be the same on yours .... |
tnttmp99 Guest
Posted: Mon Nov 06, 2006 9:53 pm Post subject: portable dvd repair training manual |
I am interested in going in the repair field of portable dvd players,
where can I go to find basic information on dvd repairs? : : |
905 x Philips • 1964-04 Agilent • pc0689p . Various • cm1300 15c se Philips • 2sc2937 Inchange Semiconductor • bd301 Inchange Semiconductor • manualst Philips • WAV 9100 User Vol. 1 Wavetek • CTV2540, CTV2543, CTV2840, CTV2843 OVP • XR-C9100R Service Manual Sony •
