Fran
Posted: Sat Nov 04, 2006 5:02 pm Post subject: sony dvd hcd-s500 please help |
Hi my dvd just gave up reeding the dvd and cd put in disk it start to run nomal speed than goes slow speed does this a few cycles and than stops and say <NO DISC> i already cleaned the lense with Isopropyl lcohol no avail any help thanks in advance[2761] |
carcus
Posted: Sat Nov 04, 2006 6:48 pm Post subject: |
i have quite alot of repair notes from memory on this model but i will not be able to see them untill monday or tuesday ... i'll post again after i have looked at them ... perhaps someone else may be able to help you before then but if not i will post again monday or tuesday |
Posted: Sun Nov 05, 2006 12:15 am Post subject: |
While there were several issues with that unit, more than likely need to replace the laser assembly---comes complete with motors.
A6062705A
---& don't forget to remove the shorting on the new pickup. |
Frank Guest
Posted: Sun Nov 05, 2006 12:39 am Post subject: sony dvd hcd-500 |
Thankyou IVTECH |
Posted: Mon Nov 06, 2006 9:18 am Post subject: |
if it didnt need a laser assy before you cleaned it with iso it will now as the iso will damage the coating on the lens, dont forget to check q02 on dvd pcb has been replaced with the modified version but that also usually prevents eject from wrking. |
carcus
Posted: Mon Nov 06, 2006 9:40 am Post subject: |
the only notes i have on my service manual is D909 on the power supply board for no DVD operation but i didn't note any more than that.... also IC302 for No DVD operation or the error message "C-81" is displayed.
otherwise a faulty laser assy ....
i have been using iso to clean laser lenses myself for 3 and a half years without any problems ... i also use a proper lens cleaning liquid afterwards as this removes any smearing on the lens but i always use iso first as it cleans any contamination off better than just the lens cleaning fluid itself ...... |
samsung ph63klflbc-xf chassis d84c Samsu • LX3700D Philips • LG 65EG9600 ub Chassis EA59E sm LG • 2sd2321 e Panasonic • T 7000 Grundig • DVD710 SB-SI 4651209001 Philips • B100 027 CANON • fdms9620s Fairchild Semiconductor • PC PC07X2 CHASSIS TV D LG • tys New 2011 possibly •
