nohilow Guest
Posted: Tue Nov 14, 2006 1:11 am Post subject: okidata c5100 feeder unit disassembly |
I started to print out a couple of laser cd labels before I remembered I had only 1 sheet of cd label paper in the printer. Hoping that the cycle was not to far advanced, I pulled open the paper tray to put in some more as the single sheet cd paper was being pulled up into the machine.
When I opened the paper tray, the machine stopped mid-feed. I pulled out the paper tray and pulled out as much of the sheet from bottom of the feeder unit as I could. However, some of the label pelled off into the rollers.
I pulled all the visible labels off the exposed parts, but evidenlty some of it got a little farther in the rollers because when I turn it on, I get a "front cover paper jam" error message. I looked the assembly over, and it looks like only 4 screws hold the rollers down. I took them out, and the assembly will NOT release.
I downloaded your service manual, but the dis assembly procedure of that part is not too specific. It shows a screw coming in from the front but I cannot find it on mine.
Does anyone have any experience with this problem? Perhaps I have to clear the error message from the config menu? But I DO think there is probably some part of an adhesive label causing the error.
HELP!
-Nohilow[img][/img] |
MX800 Samsung • DVA-206LX Инструкция Funai • servo schematic diagram MYSTERY • • fw-46 fw-56 246 Philips • irl1004 International Rectifier • 2sb885 Inchange Semiconductor • dta143tca HT Semiconductor • system block diagram LG • ET News Letter 1955 IBM •
