tracktor Guest
Posted: Tue Nov 21, 2006 5:16 am Post subject: philips tubes |
Hello I was told I need my green&blue tubes filled on my philips 7p033w102 could someone tell me what a ballpark price for this job should be I have been told everything from 350-to575 |
stevestar999 Guest
Posted: Wed Nov 22, 2006 1:17 pm Post subject: |
First take a flash light and take a look down inside the tubes. Offset the flash light beam when shining it through the lens, so you can see if the fluid levels are low. If the fluid levels are low, that means they are leaking. Make sure they haven't been leaking on the circuit boards. If someone is going pull the tubes and do the seals, $350 is fair. Whats your picture look like? Low fluid looks like, half the picture is OK and the other half looks fuzzy. Now if you've got contaminated fluid the whole pix can look fuzzy. If you've got a dirty mirror and lens, that can make it look fuzzy. Take the screen off, turn the set on and take a look down into the lens. Warning, squint your eyes a bit. It's going to be bright. |
tracktor Guest
Posted: Wed Nov 22, 2006 3:22 pm Post subject: phihips tubes |
Thanks Steve I looked into the tubes the red one looks alot clearer than the blue and green you can barely see an image on blue&green. |
tracktor Guest
Posted: Wed Nov 22, 2006 3:25 pm Post subject: philips tubes |
I looked into the lenses not the tubes |
