frank Guest
Posted: Wed Nov 22, 2006 12:12 am Post subject: battery charger |
I have a olympus camara and the charger modle# LI-10C input 100-220v output4.2v i just bought a new batterymodle#LI-12B, now the battery wont charge i realy dont know if the problem is the battery {New one] or the charger itself,it blinks continous, the charger and the battery have 3 outputs, one is positive, the other is negative, and one in the midle, now can you tell me how can i measure voltage output? i tried to mesure + to - i get 002.2milivols i tried to jump negative with the midle one and mesure against the positive but dont get steady volts, please advise me how to go about it, i dont wont to by onother battery or charger without knowing what is bad or through away the camara it self. thanks in advance. |
jacques.noir Guest
Posted: Thu Nov 23, 2006 2:51 pm Post subject: Battery Charger |
If you don't get a voltage across the + and - of the charger then the charger is probably defective. Also check to see if the battery shows the voltage it's supposed to across the + and - terminals. Often if the battery is really dead, the charger will show it as defective. This happens when a new battery sits around uncharged for a while. |
13255-91095 Sweep Module Aug76 HP • un32c5000qf un37c5000qf un40c5000qf un46 • 02-rh26-sysmod NOKIA • CM-7215CD midi hifi system+CD TOSHIBA • cep13n10l ceb13n10l CET • Panel LG Display LC470EUH-RDM1 0 [DS] . • TK-8100H Kenwood • KDC-MPV619/MPV7019/MPV7020/MV6521 kenwoo • L0D90T Philips • actual clock 3622 sm Nordmende •
