berniedd
Posted: Wed Dec 13, 2006 5:30 pm Post subject: Need Schematic for Sharp 21v-u63 CRT tv |
Hi guys. I need a schematic for Sharp 21V-U63. It showed vertical sweep collapse (horizontal line only) and shortly became dead. I've already replaced the shorted HOT and also the Vert output IC. Flyback tested OK on a FBT tester (even good HV spark). I've also replaced the Chopper IC on the main power supply board, but still the set emits a high pitched soft whine from the power supply PCB. Components in and around the horiz and vert sweep circuits are OK. So are those on the main power supply board. Thanks in advance. |
berniedd
Posted: Sat Dec 16, 2006 2:33 pm Post subject: |
addendum: Found other problems in the power supply board- shorted power zener R2KN, bad error voltage amplifier SE120. I just don't understand how these things fail from the original bad vertical output IC which caused the HOT to overheat since the IC gets its B+ from the flyback. Just a fluke maybe? |
HD781210 Philips • 62-5010 Radio Shack • SU-A6MK2 Technics • 2624 Secure Access TN Keithley • compaq ch5battery HP • CLIP 5062-7754 Gate Card. Agilent • Studio 2 Resprom • 19665-90001 2000FAccessConv HP • [radial thru-hole] RE3 Series Elna • 201 Fisher •
