DANT
Posted: Sun Dec 31, 2006 1:14 am Post subject: OSD has gone black!! - sony kd32dx100 television |
Hi, I have a sony kd32dx100 television. I made some minor adjustments to the picture size in the service mode 'deflection' menu. This was OK, but suddenly the OSD went black such that I could no longer see any text or values. This is not restricted to the service mode OSD but the OSD at all times, meaning conventional picture and sound adjustment etc is not possible. The picture itself is fine.
Seems it might be a bug in the internal software.
Any suggestions on how this could be rectified would be very much appreciated![/code] |
Posted: Sun Dec 31, 2006 2:46 am Post subject: |
Sounds stupid but, did you unplug the set for a bit and see if you can re-enter the service mode? |
DANT
Posted: Sun Dec 31, 2006 10:13 am Post subject: |
I can re-enter service mode no probs, but the OSD is still black so I cant see anything to change! |
Posted: Mon Jan 01, 2007 8:32 pm Post subject: |
Can you bring up the menu when your not in the service mode? |
DANT
Posted: Tue Jan 02, 2007 10:20 pm Post subject: |
Yeh, the menu comes up, but just as a black box. |
Posted: Wed Jan 03, 2007 1:40 am Post subject: |
Did you try bringing up the screen control on the flyback? |
Posted: Wed Jan 03, 2007 4:40 am Post subject: |
I believe one of the functions in service mode is in fact the OSD brightness level. That may have been the one you tweaked accidentally. I'm not sure which one it is, (IE how many button presses to go into the mode)
If you have NOT saved the changes you have made, you are probably still good! UNPLUG the set, and let it sit for 30 minutes or more. Plug it back in, and try again. BTW, if you didn't save your other adjustments, they will also return back to their previous settings too! |
Posted: Wed Jan 03, 2007 8:31 am Post subject: |
Thanks for your help, but I've already tried leaving the set turned off as a last ditch effort, and sadly nothing changed! |
Posted: Wed Jan 03, 2007 8:04 pm Post subject: OSD has gone black!! - sony kd32dx100 television |
Out of curiosity does TEXT and TEXT mix work o.k? |
Posted: Wed Jan 03, 2007 11:08 pm Post subject: |
DANT wrote: | Yeh, the menu comes up, but just as a black box. | |
