Frank Guest
Posted: Sun Jan 07, 2007 9:39 pm Post subject: RCA atc113aa |
Hi Guys, It.s me again with the RCA ATC113AA Has been giving a Headache.
I started with dim picture i resolder everthing no avail. then turned up g2 have enough bright but get bad poor covergency on greens. when i turn down the G2 to the rihgt level where i can get a good pic and convergence,then when turn off set then turn back up again the pic is dim or without bright,i have to keep the G2 a litle bit higher thus degrades the green convergence,I don't have sckematic, i suspect either FLY or IC TDA6107G Video Amp, any ideas thanks in advance.
Took measurements of the IC Drivers Amp TDA6107G ,
Unplugged the CRT board from the neck of the tube, turned on set. This were the measurements Pin #1=1.6v,2=1.5v,3=1.5,4=0.00,
5=5.00v,6=193v,7=160v,8=160v,9=154v,
I plugged in the CRT board in the neck of the tube, turned on set. P#1=1.9v,2=2.3v,3=1.7v,4=0.00v,5=5.00v,6=192v,7=150v,8=119v,
9=139v,all this was taken from the hit sink G. and with no RF connection
also Measured G2 on the crt board while i was turning up and down the g2 control, minimum control 151v,maximum 380v |
Posted: Sun Jan 07, 2007 9:49 pm Post subject: |
Sounds like you may be fighting a bad crt. |
Frank Guest
Posted: Sun Jan 07, 2007 10:17 pm Post subject: |
Minnie you talking about the tube itself or ctrt board? |
Posted: Sun Jan 07, 2007 11:01 pm Post subject: |
The tube. G2 sounds ok. Stick a hv probe under the cap of the flyback and see what your voltage is. If it's around 20k,,, I'd suspect a bad picture tube. |
Frank Guest
Posted: Mon Jan 08, 2007 12:12 am Post subject: |
I don't have a HV Prove. so i'll wait for one other tv with the same tube to show up so i can test this chassis in it . |
70CS03S 63CS03S Sharp • CP-14B86 LG • 2sc3710 Inchange Semiconductor • 9800544-04D Intellec Series II Schematic • USB Protocol Analyzer & Jammer Software • VSX-07 09 D906 RRV1770 Pioneer • 2sc2951 Advanced Semi • hfe pioneer m-790 service Pioneer • 55pfg5100 tpm15.3l la Philips • 2sd1788 Inchange Semiconductor •
