timh Guest
Posted: Mon Jan 08, 2007 10:32 pm Post subject: Kenwood AR-304 Receiver: Volume Display Negative |
I was attaching some new speakers and antenna to my receiver when the sound stopped (I may have inadvertently unplugged the unit during this process). When I adjusted the volume, I noticed that the numbers were negative. As I turn the dial from left to right, the numbers increase from, say, -65, -64, -63,...-2, -1, 0). When it gets to zero, the numbers do not go positive, it just stays on zero.
According to the manual, you can reset the system by holding down the power button and then plugging in the unit. This may have reset the system but it did not correct the problem. Thoughts? |
fongs Guest
Posted: Mon Jan 15, 2007 7:31 am Post subject: Re: Kenwood AR-304 Receiver: Volume Display Negative |
timh wrote: | I was attaching some new speakers and antenna to my receiver when the sound stopped (I may have inadvertently unplugged the unit during this process). When I adjusted the volume, I noticed that the numbers were negative. As I turn the dial from left to right, the numbers increase from, say, -65, -64, -63,...-2, -1, 0). When it gets to zero, the numbers do not go positive, it just stays on zero.
Hi there,
Does your amp still works?
Your amp is displaying the Volume in dB gain. It's normal function as 0dB is the max. gain of the amp. |
taecsupertech Guest
Posted: Mon Sep 24, 2007 1:03 am Post subject: ar-304 remote codes |
My Ar-304 remote stoppe working, I am not sure if it is the unit or the remote. Does anyone have the remote codes in a file that I can use with a universal remote?
please reply [email protected] |
