ashish1307
Posted: Tue Jan 16, 2007 2:32 am Post subject: Philips 21GR1366 (GR1AX Chassis) problem |
The set trips immediately if turned "ON" in cold state. If the set is kept in Tripped state ( Supply ON, Set Tripped) for about 5-6 minutes and then it is turned "ON" the set operates perfectly. There is no other problem. I suspect some capacitor to be leaky. Kindly suggest remidial measures.
Regards,
ashish1307. |
allanm
Joined: 10 Nov 2006 Posts: 19 Location: kilmarnock UK
Posted: Tue Jan 16, 2007 12:07 pm Post subject: fault |
C2523 6.8uf can cause this. Also thyristor 6641. Try putting a soldering iron on the end of each capacitor then switch on the set. This usually finds the culprit.
Allan |
allanm
Posted: Tue Jan 16, 2007 12:36 pm Post subject: |
Only put the soldering iron on each cap for a few seconds and obviously remove it before you switch on. |
21NI60 02 Erisson • FT-7B Schematic YAESU • Panel CMO N173O6-L01 0 [DS] . Various • GLP23A TX-26LE8F TX-26LE8FS TX-26LE8L TX • 2sb1192 Inchange Semiconductor • E3633A and E3634A DC Power Supplies Serv • 2sa940 LGE • 2sa1263 Toshiba • KCD-139 Kenwood Radio CD • Installing-Heat-Shield-2 apple •
