Frank Guest
Posted: Tue Jan 23, 2007 12:57 am Post subject: RCA CTC197AH F27680GY Headache |
Hi Guys,.Me again,This set had good pic after i did some convergence adjustements,but now the set runs great for 45 minutes, and sudden gets a Horizontal 5 inch pic top to butom and fades away with no raster just blunk screen, but sound is good,at first if i unplugged from the wall and let tv sit for awhile and plugged in back again it would come on, but latly it doen't come on no more,has no lit at the yoke, Took some tests,i have 165v at the big cap,175v fluctuating at colector of the hot,and 318v at g2 in the crt board with crt socket plugged in or out, also have only 40v at red green and blue drivers emitter, when should have 135,138 140. Hei i have changed chassis put in one ctc 177AF and set is running great. so tube is good.
Also i suspect either flyback, or hot under load, i'm going to unsolder the hot and measure it out of the circuit , testing with the ohmeter in place i should have 20ohms, but i only have 12 ohms,but i'll check it out,i don't want to spend any money on this set. that i'm not shure what component is bad, i also went through all resistors and the seemm alright allthough some are a bit discoloured with the hit. i also have an elctrolict cap in the crt board that is high ESR but i am not shure that is the cause off shut down ,any news i'll post thanks. Hei i have changed chassis put in one ctc 177AF and set is running great. so tube is still in good shape |
Frank Guest
Posted: Tue Jan 23, 2007 11:49 pm Post subject: |
| Still with RCA problem I just learnd correct me if i'm wrong,>There is an ERROR code,when i enter the service menu #1,#2,#3,are ERROR CODES.and #1 sais 10,and the other two say 0. also i got the code list and it sais 10, this code means FPIP power supply at reset,what you guys think any suggestions, the set still runs for 45 minutes and shuts the horizontal down keeping sound any help thanks. |
f217tune LG • LCD tv LC4.3HE AA Philips • SM 312278513321 EN.part3 Philips • FX-880 Part List epson • JW EDN p3 Fluke • Viore PDP42V18HA VIORE • Panel CHIMEI INNOLUX V546HK3-PS1 0 [DS] • HCD-MX500i_HCD-MX550i SONY • Kyocera FS-1010 Parts Manual Kyocera • 422 Tektronix •
