ST.G
Posted: Mon Feb 05, 2007 11:48 pm Post subject: PHILIPS 21PT2682 COLOR TV |
When power is turned on the main power switch,red LED lights then and disappear signaling power is ok but then goes to standby mode lighting the red LED again. I replaced the vertical out IC tda9302h and it worked but not for long. The same problem occured again,shutting high voltage and going to standby mode again. I replaced the vertical out again but did not cure the problem....Any ideas causing the tv to go to protect mode?Thanks for your time.God bless us all !!! |
Frank Guest
Posted: Tue Feb 06, 2007 12:13 am Post subject: |
There may be no 5V to the microprocessor. Check R3509 and D6501. Replace R3509 with a 47k 1 Watt version (4822 053 10473). D6501 is type BZX79B5V6 (4822 130 34173). Check the +150 volt rail, 145V is too low |
Frank Guest
Posted: Tue Feb 06, 2007 12:20 am Post subject: |
before checking all the components that i stated in the other post, chech the caps and ESR them they may check ok but they high esr . and resistors in the vertical. |
ST.G
Posted: Tue Feb 06, 2007 10:34 pm Post subject: PHILIPS 21PT2682 COLOR TV |
There is +5V at the microprocessor. The actual B+ at standby mode is 106V and goes down to +95V when power is on...Thanks |
