ramtour2
Posted: Thu Dec 30, 2010 6:24 pm Post subject: resistor values |
The resistor values are:
R912 = 1.2 5%
R913 = 3.6 5%
I would like to know what caused them to burn. I got these valuse off a replacement power supply. |
Posted: Thu Feb 17, 2011 1:41 am Post subject: |
aparnell wrote: | Does anyone know the values of resistors R912 &913 on the power board? I am working on a L32HDTV10A. IC901 burned and I can't see the value to check them. Thanks. |
Do you have part number for IC901 - L32HDTV10A? mine need to replace but I could find part number. |
Posted: Thu Feb 17, 2011 2:57 am Post subject: |
ICE3B1565 made by Infineon. But it may not be the only problem as someone posted earlier in the thread |
kb3
Posted: Mon May 30, 2011 12:52 am Post subject: |
A friend of mine was watching his L32HDTV10A a week ago when he heard a bang that he at first thought was a gunshot. Apparently it came from the Vizio since it immediately went dark and completely unresponsive. No lights. No LEDs. No sound.
Have tried unplugging for extended periods, replugging, holding power button while replugging, pressing green micro-switch (whatever that is for) on main circuit board. No change. No lights. I found the fuse on the power board and was hoping that it would be as simple as replacing it, but after removing and checking it the fuse seems to have continuity. I have examined all the caps on the power board and main board and see no sign of explosion -- or even bulging or leaking. (Wonder what caused the bang!)
I am much more familiar with computer hardware than with TV hardware, but I am guessing the problem is with the DPS-199APA/0500-0507-0180 power board. Looks like I would be able to pick up a used one on eBay for about $65, since new ones seem to be "out of stock" everywhere. Did find a rebuilt 0500-0507-0240R on partstore.com that claims to be compatible, so maybe that is a better choice -- just getting a little pricey at this point...
Any other suggestions on where to go from here? Thanks! |
Homer78 Guest
Posted: Mon Jul 04, 2011 2:47 pm Post subject: How do I know if it is my power supply? |
Our TV went out after a very close lightening strick. I'm not sure if it actually got "hit," because everything else on the surge protector still works fine. However, the TV quit turning on. I don't want to pay the $85 for the ps and find out it still doesn't work. What are the chances that it is just the power supply? |
LKnitter Guest
Posted: Wed Sep 07, 2011 7:53 pm Post subject: Re: How do I know if it is my power supply? |
Homer78 wrote: | Our TV went out after a very close lightening strick. I'm not sure if it actually got "hit," because everything else on the surge protector still works fine. However, the TV quit turning on. I don't want to pay the $85 for the ps and find out it still doesn't work. What are the chances that it is just the power supply? |
Did you find anything out on this as we have the exact same problem!! THANKS! |
kurtrow Guest
Posted: Thu Sep 22, 2011 4:55 am Post subject: power supply |
I'm trying to repair a power supply (199AP) for this Visio 32" set and could find no problems, but no voltage at all comes out, not even the housekeeping 5v. Then noticed the thermister is cracked, so pulled that out. But now I can't figure out what to replace it with. Anybody know what thermister is used for 'NTC1' on the board? Or maybe there is a workaround? |
train123
Posted: Wed Sep 28, 2011 6:37 pm Post subject: |
You can usually read the numbers on the thermister and cross it to an equivalent. Here is a site to try. http://www.nteinc.com/ |
hdman97
Posted: Sun Oct 02, 2011 5:58 pm Post subject: |
Anyone done repair on main board? no picture no sound |
Posted: Sun Oct 02, 2011 7:03 pm Post subject: |
Nope. Technicians are all just board swappers now. _________________ You're over there, I'm over here. |
