pigaz Guest
Posted: Thu Feb 15, 2007 10:11 am Post subject: Power supply |
I need help about Power supply it generate 5V 12V 3.3V ...
when it not connected to mother board but when connected the LED of PC still flashing the PS model is HP-P2507FWP for Dell gx270 |
gilloz
Joined: 03 Feb 2007 Posts: 33 Location: So. Cal High Desert
Posted: Sun Feb 18, 2007 5:02 pm Post subject: PSU |
I am assuming that your PC does not go into the boot-up sequence when you switch it ON, is that right? You could try disconnecting all but the essential items and see if you still have the same problem. Keep items like the primary HDD, video card(if not integrated) and memory. Disconnect sound card(if not integrated), removable drives(DVD,CD,Floppy), speakers and modem. |
robin_bga Guest
Posted: Tue Feb 20, 2007 2:53 am Post subject: Re: PSU |
gilloz wrote: | I am assuming that your PC does not go into the boot-up sequence when you switch it ON, is that right? You could try disconnecting all but the essential items and see if you still have the same problem. Keep items like the primary HDD, video card(if not integrated) and memory. Disconnect sound card(if not integrated), removable drives(DVD,CD,Floppy), speakers and modem. |
I agree with GILLOZ's assumption, i have delt with DELL more often and they have the problem and the best u can do for it is to order the same PSU, i create a reverse electric current the shorts the main FET TRANSISTOR and the GROUND, usually called a LEAKAGE, it can raise upto 5/6 volts that is alot of voltage, in Uganda we have a problem of spare parts, so i discover that i can disconnect the Ground and that FET the connect a HIGH RESISTANCE RESISTOR of atleast 20/30mega ohms, and it works fine. for yo can u can't count on that so try and order a new PSU, its u be the same or slightly higher.
Pliz let us know of yo progress.
Wish u luck Robin |
robin_bga Guest
Posted: Tue Feb 20, 2007 2:55 am Post subject: Re: PSU |
I agree with GILLOZ's assumption, i have delt with DELL more often and they have that problem and the best u can do for it is to order the same PSU, they create a reverse electric current the shorts the main FET TRANSISTOR and the GROUND, usually called a LEAKAGE, it can raise upto 5/6 volts that is alot of voltage, in Uganda we have a problem of spare parts, so i discover that i can disconnect the Ground and that FET the connect a HIGH RESISTANCE RESISTOR of atleast 20/30mega ohms, and it works fine. for yo can u can't count on that so try and order a new PSU, its u be the same or slightly higher.
Wish u luck Robin |
reytan_58 Guest
Posted: Fri Feb 23, 2007 7:08 am Post subject: monitor |
plzz help me!!! my problem is no B+.hitachi 17" pc-dc3576 model.thnx |
4A141 AirChief • t1 LG • hfe denon avr-1912 2112ci schematics DEN • WD-6021 C LG • 2n6674 2n6675 Inchange Semiconductor • Universum_Modell-Chassis Universum • mps6514 Fairchild Semiconductor • ceu02n6a ced02n6a CET • Alan-4522 MIDLAND • SLV-X717 X817 X827 X837ME Sony •
